Since a lot of us don't know whats legal & whats not when it comes to wheels & Tyres..... here is a doc I found which has all the states minor wheel & tyre modifications summed up in one document. Since several states have different laws.
this is for info only........don't knock on my door if you get defected.
http://www.toyo.com.au/TechInfoPDFs/Alt ... ations.pdf
my own personal interest was to see how different some of the states are to NSW & in what regard.......
Whats Legal & whats not
- StanTheMan
- PASHN8
Well in Vic, it's a plus 2 rule, which is you can fit a wheel that is no more than 2 inches larger in diameter than the largest wheel size offered in the body shell.
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- fig
PASHN8 wrote:Well in Vic, it's a plus 2 rule, which is you can fit a wheel that is no more than 2 inches larger in diameter than the largest wheel size offered in the body shell.
Relative to the Tyre/Wheel Placard, but they can be changed cant they
Then
10AE (#3062)
Now
'08 Porsche Boxster S modified ;-b
'11 Porsche Cayenne 22's FTW
'78 Porsche 911SC - Old Skool Hotness
'67 Porsche 912 - Fav!
10AE (#3062)
Now
- PASHN8
No, it's actually relative to the vehicle/Vin build type. Placard is only useful when being hassled by the boys in blue
- 2005 MX-5 SE
- fig
PASHN8 wrote:No, it's actually relative to the vehicle/Vin build type. Placard is only useful when being hassled by the boys in blue
Then
10AE (#3062)
Now
10AE (#3062)
Now
- StanTheMan
you'll find that rule to be a myth.
http://www.vicroads.vic.gov.au/NR/rdonl ... 0/VSI8.pdf
check section 8
and its basically repeated in the above document.
the great thing about the above doc is that is has all the states combined. I was courious about SA rules & regs since the forum membership has increased heaps in SA. I could'nt find a thing......& stumbeled over the above document. Which tells us to refer to Tasmanian Rules
Edit *changed shortcut to direct link*
- Bevan
- PASHN8
StanTheMan wrote:PASHN8 wrote:Well in Vic, it's a plus 2 rule, which is you can fit a wheel that is no more than 2 inches larger in diameter than the largest wheel size offered in the body shell.
http://www.vicroads.vic.gov.au/Home/Car ... efault.htm
check section 8
Hmm, interesting document, I wonder how new it is? The plus 2 rule has been enforced in Vic for as long as I can remember, including being told by Police officers myself a few times when questioned by the side of the road?
I'm pretty sure the Police enforce Vicroads rules, or do they enforce their own when it comes to defects?
- 2005 MX-5 SE
- StanTheMan
if its been around since ever.....has it maybe occured to you that its maybe an old rule.
coppers are not any better than us. They can be misinformed as well.
I can't garantee this document is up to date. But i can't find a doc which has the max 2 inch rule.
funny though how 2 docs state the same thing.
