front indicators
spikey
front indicators
Postby spikey » Fri Jan 12, 2007 9:48 pm
Is there a easy way of removing the front lens off the front indicators?so I can remove the orange in it.it seems to be glued on tight,that it might break if you try to prise it apart.any suggestions would be great.
Thanks
Richee
Postby Richee » Fri Jan 12, 2007 11:36 pm
Steve 818 wrote:A heat gun on a low setting or a decent hairdryer will melt the glue/stuff and you should be able to carefully prise it apart with a couple of flat screwdrivers and some patience.
Very carefully and lots of patience ... I put mine in the oven for about 30 mins at 100 degrees. Result is well worth the effort though.
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
Moggy
Postby Moggy » Sat Jan 13, 2007 1:01 am
I also put mine in the oven. :) Although I find that five minutes or less on 120 is sufficient...
Craig
Postby Craig » Sat Jan 13, 2007 1:06 am
kitkat
Postby kitkat » Sat Jan 13, 2007 1:21 am
Oven here aswell!!!
And use several BUTTER KNIVES to pry it open. being thinner, wider and slightly flexible helps ALOT!!!
After that you can cut and swap positive wires so that the little side lights are blinkers (with orange bulbs). It will blink faster but you get over that, i just figured it helps my indication get noticed.
Boags
Postby Boags » Sat Jan 13, 2007 9:15 am
Oven here too. Be VERY CAREFUL. If the glue isn't quite melted you will snap the plastic. :oops: Trust me. :roll:
And while you have them out, shave them and polish them too! :mrgreen:
Boags
JSE
Postby JSE » Sat Jan 13, 2007 9:56 am
Read this thread... it will tell you everything you need to know
http://www.aus-cartalk.com/viewtopic.php?t=17543&highlight=lens
Fatty
Postby Fatty » Sat Jan 13, 2007 10:12 am
so if you leave the original indicator globes in as your \"driving lights\", are they bright enough? or should you upgrade them?
Philip Lee
Postby Philip Lee » Sat Jan 13, 2007 10:17 am
oven here but it was a hell of a job. thanks for your help wayne 8)
Boags
Postby Boags » Sat Jan 13, 2007 10:57 am
Fatty wrote:so if you leave the original indicator globes in as your "driving lights", are they bright enough? or should you upgrade them?
Definately bright enough, I think some even say they are "too bright" for side lights! Think of the poxy little globes which do the job now. :lol:
I'm going to change them over soon too.
Boags
JSE
Postby JSE » Sun Jan 14, 2007 10:03 am
Rodent did the swap. They were really bright, almost too bright IMO. But the indicator couldn't really be seen when turning from the front...I've had this problem as well, other drivers cannot see the indicator int he sun because the bulb has nothing to reflect a brighter shine off.
kitkat
Postby kitkat » Sun Jan 14, 2007 11:57 am
Yeah, ive been a bit worried about people not seeing the indicator aswell.... im going to try and put a bigger bulb in.
But as been said the parkers become very bright... and because of the reflector shape it shines up into peoples cabins...
Moggy
Postby Moggy » Sun Jan 14, 2007 4:57 pm
kitkat wrote:...and because of the reflector shape it shines up into peoples cabins...
Woohoo! Finally some revenge against those 4WD's out there that consistently burn my retinas... :P
AJ
Postby AJ » Sun Jan 14, 2007 5:42 pm
well, don't whinge when a truckie runs clean over the top of you because of your stupid illegal lights :evil:
XMX5 Rogues
green_comet
Car Detailing Guru
Postby green_comet » Sun Jan 14, 2007 8:13 pm
Now now Ladies.. :shock:
Anyways, this is from a post i made about a year ago.. Hope it can be of some help Spikey.
you can pull the ones you have apart...
I did it to mine with a flat blade screwdriver and a hairdryer. The orange bit inside is just held in with 2 screws, You should try it, very easy to do will take you an hour or so. I also swaped my indicator with my parking lights, so now the indicator is on the outside where the parkers where.
Heres a step by step guide for you, if your interested.
http://www.mx5club.org.nz/maintenance/driving_lights/
Heres how it looks on my car.
cheers
Ryan
