Hey guys.
I think i'll be needing new tyres in a few months.
I've got an alignment problem which is causing uneven tyre wear.
Do you think its better to:
1) Fix alignment now then get new tyres later (and not get another alignment) [current plan]
2) Wait till i get new tyres and then fix alignment?
3) Fix alignment now, get new tyres and then re-do alignment?
I can't think of a reason why I would need to get a new alignment JUST because I get new tyres.
Thanks.
Alignment Qtn - now or after?
- AJ
no WAY i'd ever put new tyres on & NOT get a wheel alignment............as for your situation, depends on how much life is left in your current rubber & whether leaving it will actually shorten the life you have left...........it'd be either 2 or 3 for mine
XMX5 Rogues
- AJ
dunno about THAT, but it's just good policy when you spend good $$ on new tyres, you want to get maximum life possible, & if your alignment is even out a smidge, it won't take long to show up in treadwear on new, soft tyres, & once tyres start to wear a particular way, it's very difficult to correct.....IF you go with 1, at least get the alignment checked when you do put the new tyres on
XMX5 Rogues
Insurgence wrote:thanks
ahh icic. guess every little bit counts
i went and measured the tread again, i think i'll just wait till i get new tyres to get the alignment done...
3-4 mm all round. not long now!
So what's wrong with the tyres, as in how is it unevenly worn?
Cos a lot of times incorrect tyre pressure can influence uneven tyre wear, not just alignment.
Users browsing this forum: No registered users and 216 guests
