HKS VPC installation?
Astroboysoup
Postby Astroboysoup » Fri Jan 12, 2007 3:21 pm
Does anyone have instructions or has any idea on how to install this?
Just got mine. Thanks Quark.
Little old piece of technology :)
Postby 93_Clubman » Fri Jan 12, 2007 5:03 pm
Astroboysoup
Postby Astroboysoup » Fri Jan 12, 2007 5:11 pm
yeh i googled alot of information and i think im ok with the install now.
I just have the air temp sensor and the pressure sensor.
they're pretty straight forward.
The main thing that I was wondering about was the hot wiring of what pins on the AFM cable so that it will continue to pump fuel.
Astroboysoup
Postby Astroboysoup » Fri Jan 12, 2007 5:21 pm
im just googling and searching the wrong terms..
it has to be written somewhere on the net already
Fatty
Postby Fatty » Fri Jan 12, 2007 5:48 pm
yeah you need to jumper those fuel pump shut off wires on the afm somehow. from memory i think this can be done in the diagnostics box in the engine bay. i think i remember readin about that somewhere.
Astroboysoup
Postby Astroboysoup » Fri Jan 12, 2007 6:48 pm
Light green and black - fuel pump switch in the AFM
http://www.madracki.com/miata/images/wiring/90diag.pdf
pg 4 in the wiring diagram PDF
Keywords for future searchers
jumping, air flow meter, removal, hot wiring,
Astroboysoup
Postby Astroboysoup » Fri Jan 12, 2007 8:43 pm
yeh all installed now.
what settngs did u have it o for stock cams?
Roderic
Postby Roderic » Wed Jan 24, 2007 1:02 am
It's best to get tuned on a Dyno if you can......not worth screwing up. Can cost you $$$.
Thanks to:
Alberts Car Stereo-Fabrication/Stereo
Imports 101-Compliance/Mechanical
Miata Mania-Various
MX5 Mania-04 NB Interior
MX5 Plus-Engine, Gearbox, Brakes, Diff
MX5 Parts.UK-Rear Tail Lights
Prestige Motorsport-Importing
Wheelspin-Mechanical
Astroboysoup
Postby Astroboysoup » Wed Jan 24, 2007 8:49 am
got an ok set up right now
installing tha jaycar dfa friday and then dyno tune the following friday
AustCars.net - It's like Facebook but for cars!
