2007 CAMS NSW Supersprint Championship
greenMachine
Postby greenMachine » Tue Jan 09, 2007 9:28 pm
Girls and boys, old hands and new chums, contenders and dabblers all
Now that 2007 has arrived, it's time to start thinking about streching our boundaries, and trying something different. That 'something' could be the State supersprint series.
Registration is now open for the 2007 CAMS NSW Supersprint Championship.
Now, that title sounds rather grand, but don't be put off by that. What it amounts to is another track day, just like our club days down at WP. If you have done a few track days with the club, or elsewhere, you should not be deterred by this series. They are run the same way, competitors compete in classes/types, and are grouped on the track according to lap times (real or estimated if you haven't run on a circuit).
Again, if you haven't run at one of the circuits, you will pick it up pretty quickly by following others in your group (there is no practice or training at the rounds normally, as they are not intended for first timers).
What you will get is a big variety of cars, and meet some new people with our interest in fast cars, and have a lot of fun.
Registration costs $50, that gets you access to an early 'registrants only' period to lodge your entry prior to general entries opening for each of the eight rounds, eligibility for points towards the championship, and a highly subsidised prize giving lunch and skidpan day at the end of the series.
Atmo MX5s will run in the 1600-2000 Class, within one of the 'Types'. These are standard cars (Type 1), modified road registered (Type 2 - such as the Green Machine, Mike), modified racing cars (Type 3 - eg Kevin's car), type 4 is racing cars on slicks (Nick and Matilda).
All NA and NB cars will require at least a BD 'half cage' roll bar (steel, alloy not allowed), and the 50mm rule is enforced fairly tightly. You will need a fire extinguisher, gloves, a driving suit (I used a pair of King Gee overalls last year) and a secondary bonnet catch. If you have trouble meeting the 50mm requirement using the standard seat, I think you might be able to replace it with a non-standard seat (as a safety device) - but if you think this might apply to you, you need to check this out (PM me and I will pass your query on to Mike, or contact him directly at competition@mx5.com.au). This applies to Type 1 only (ie 'standard' cars), as other classes allow freedom to change seats. Oh, and a helmet and CAMS L2S licence too!
I have a copy of the registration form, calendar, rules, and eligibility requirements for the different classes/types, any of last year's competitors will have them also (see below, or PM me). The Supp Regs for 2006 were not a lot different to the ones from our track days. First round is 4 March, at Oran Park GP circuit. There are 3 rounds at OP GP, 1 at OP South circuit, 2 at Eastern Creek, and 2 at Wakefield, basically one a month with the last round on 14 October.
As some of you will know, I did this series last year. I had a great time, even though this time last year I had never set a wheel on the Sydney circuits! I can highly recommend it as \"something different\", a new challenge.
Last year we had Nick and Matilda, Darren, Mike, Ian, Stewart, John, Lindsay, Bradely, Doug, Renny, Bill, Kevin, me, and I have probably missed a couple, but you get the picture. Not everybody competed at every round (you can only count your best 7 rounds anyway), but there was a hard core there at every one.
So, who is up for it? Talk to one of the people who did compete last year, you don't have to launch a full on bid for a Class or Type result first time out, or ever, if you want to just dip your toe in at a few rounds, or just come for the fun, that is fine.
There is another reason to register, rather than just enter particular rounds - there is a Club Championship run in parallel, and our position at the top of the heap has slipped a little (IIRC we came second last year) - so your Club needs YOU!
*You still need to separately enter, and pay the appropriate entry fee, for each round.
Li7hium
Postby Li7hium » Thu Jan 11, 2007 8:36 am
Seriously tempted by this.
I've read the 2007 CAMS regs, and I have going to have to get a aftermarket seat to comply with the 50mm rule. I'm thinking something like the OBX one Bigdog got as it seemed to drop his height level a fair bit according to the aftermarket seat thread.
Secondary bonnet restraint - What are we talking about here? A cable tie connecting the primary bonnet restraint together, will that suffice?
C'mon Andrew, you KNOW you wanna!
Matt
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
greenMachine
Postby greenMachine » Thu Jan 11, 2007 9:23 am
Matt, I used a couple of short lengths of nylon webbing, with a couple of those plastic buckles, until the bolt holding one end came undone and I lost that half. Since replaced with a belt (as in trousers, for the holding up) cut in half. Not as sexy, but just as functional.
Sparco Sprint seat will fit, check dimensions before you part with $$ for a seat, the MX is rather narrow. Also, if you are going to run Type 1 (standard cars), check with Mike first.
Li7hium
Postby Li7hium » Thu Jan 11, 2007 10:23 am
My car is *not quite* stock, running in the modified road registered normally aspirated class, so the seat issue should be fine.
Thanks for the info!
Matt
NA8
BRZ
Charlie Brown
Postby Charlie Brown » Fri Jan 12, 2007 9:11 am
Would have loved to have a run in some of the events but….
Well it is a NC and CAMS haven’t approved the standard “roll bar” and my big head and helmet must be at least 4” (100mm) above that bar anyway.
It is impossible to fit an aftermarket roll bar (if one was available) that’s 50mm above the top of the helmet and put up the soft top let alone retain it. :cry:
irwin83r
Postby irwin83r » Fri Jan 12, 2007 6:48 pm
Li7hium wrote:C'mon Andrew, you KNOW you wanna!
Matt
sure do...
when do reg's have to be in by??
i need a seat, roll bar and secondary restraint for the bonnet to comply.
i always said i would do sprints this year :? guess its time to eat my words :P
Li7hium
Postby Li7hium » Sat Jan 13, 2007 9:13 am
Given that I have a 1993 NA8 non-Clubman, am I going to be in Class 3 due to my aftermarket LSD?
Matt
NA8
BRZ
irwin83r
Postby irwin83r » Mon Jan 15, 2007 7:33 pm
Li7hium wrote:Given that I have a 1993 NA8 non-Clubman, am I going to be in Class 3 due to my aftermarket LSD?
Matt
i dunno i thought the LSD might be a "free" upgrade?
argueable it is standard on a mx5 of your model so you might get away with it.
much like building a "mock" SE or SP race car you could always build a "mock" clubmen surely??
greenMachine
Postby greenMachine » Mon Jan 15, 2007 10:42 pm
It is necessary to read the regs CAREFULLY, and look at all the opportunities to have mods qualify. Don't just read the diffs section - read it ALL and see how it fits together. There is more scope for mods than might first appear. :wink:
irwin83r
Postby irwin83r » Mon Jan 15, 2007 11:07 pm
greenMachine wrote:It is necessary to read the regs CAREFULLY, and look at all the opportunities to have mods qualify. Don't just read the diffs section - read it ALL and see how it fits together. There is more scope for mods than might first appear. :wink:
where can i get the full regs?
greenMachine
Postby greenMachine » Tue Jan 16, 2007 8:59 pm
PM me your email address.
irwin83r
Postby irwin83r » Sun Jan 28, 2007 12:12 pm
not sure ill have the cash to have the car ready in time so might have to give it a miss untill next year :cry:
whens too late to reg??
im keen as mustard but to get a cage and new tyres i think ill be pushing it..
might be time to get a loan for a \"motor bike\" :P
greenMachine
Postby greenMachine » Mon Jan 29, 2007 12:04 am
Irwin, you can register any time - right up to the last round! Point is, you can drop one round anyway, and if you can't be ready in time for first round, then register and compete from round 2.
Alternatively, register, and just compete in any rounds you can - that way you will get experience, and points as well, from those rounds.
irwin83r
Postby irwin83r » Mon Jan 29, 2007 1:31 pm
greenMachine wrote:Irwin, you can register any time - right up to the last round! Point is, you can drop one round anyway, and if you can't be ready in time for first round, then register and compete from round 2.
ahh ok. cool
well when i get the car sorted ill get back to you i guess :D till then ill stick to club days i guess
Li7hium
Postby Li7hium » Mon Jan 29, 2007 2:04 pm
I'm missing the opening round at Oran Park, but hope to be there for the Eastern Creek day at the end of April.
I'll be at Wakefield for the Triple Treat in March. Hoping to purchase seat, fire extinguisher mounted to the front bolts of the passenger seat rails and use a couple of D carabenas and a length of chain as a secondary bonnet restraint, in the near future.
I think that will be all I will need to comply as a road registered Class 2 entrant.
Matt
NA8
BRZ
Return to “MX5 Motor Sport”
