Tyre Pressure for 205/40/17 ?
ducktape69
Postby ducktape69 » Tue Jan 09, 2007 4:10 pm
what do you guys recommend for cold tyre pressure for 205/40/17 tyres?
keep in mind i want to keep even tyre wear but good performance....
Sam
BLECK 2002 Mazda MX5 NB8B. Custom Heatshielded CAI . KYB AGX's + King Springs. 17\" Bleck Rims. Custom BASSSS Install.
deez
Postby deez » Tue Jan 09, 2007 4:14 pm
When I had that size on my car I did 34-35 psi cold. The car felt quite good. Don't know if that helps :P
89 Eunos Roadster
lowmiata
Postby lowmiata » Tue Jan 09, 2007 4:33 pm
I run between 38 and 40 cold
to protect the rims!
depends what type of roads you normally drive on!
QLD roads are not thye best!
EVI15 1998 to 2008
Boags
Postby Boags » Tue Jan 09, 2007 7:24 pm
A lot... Don't know what that is in metric though! :lol:
Yep, over 35 cold for sure.
Fatty
Postby Fatty » Tue Jan 09, 2007 7:32 pm
bloody hell. i only ever pump mine up to about 30 :?
mine are 16's
Slugoid
Postby Slugoid » Tue Jan 09, 2007 7:44 pm
Fatty wrote:bloody hell. i only ever pump mine up to about 30 :?
mine are 16's
30 seems a bit under inflated for me. I'm running around 34psi cold with 205/45R16's. I guess the best way is to play around and try different settings.
Boags
Postby Boags » Tue Jan 09, 2007 8:03 pm
Yep, I ran about 34PSI cold in the 16s on the track. Any less with the Fuldas and it felt too floaty. Dad used to run much higher than that for spirited road driving.
Boags
timk
Postby timk » Tue Jan 09, 2007 8:22 pm
I use 32 cold on the SE rims, which seems good. When I first picked up the car they had 40 in them and that was way too harsh. For street tyres on track days I run 45 just while I am at the track to reduce sidewall flex.
kev.yan
Postby kev.yan » Tue Jan 09, 2007 10:14 pm
The pressures listed below will be a happy medium for most MX5's with most tyre sizes.
36- 38 psi Front
34- 36 psi Rear
If you drive Hard up the fronts another 2psi
also too Fatty if you by any slight chance have a warranty issue with your tyres, running below 32 psi invalidates any warranty on a modern steel belted tyre.
Hope this helps.
Kev 8)
Fatty
Postby Fatty » Tue Jan 09, 2007 10:19 pm
guess i'll be ducking over to the servo tomorrow morning for a bit more air in my tyres then :oops: :oops:
timk
Postby timk » Tue Jan 09, 2007 10:50 pm
kev.yan wrote:also too Fatty if you by any slight chance have a warranty issue with your tyres, running below 32 psi invalidates any warranty on a modern steel belted tyre.
That's really weird, the placard suggests 28 up front on the SE. Would it invalidate it in this circumstance?
Boags
Postby Boags » Tue Jan 09, 2007 11:55 pm
The race guys have said previously that MX5s run best with the same pressure all round. Just being a parrot.
Boags
Charlie Brown
Postby Charlie Brown » Wed Jan 10, 2007 1:19 pm
kev.yan wrote:The pressures listed below will be a happy medium for most MX5's with most tyre sizes.
36- 38 psi Front
34- 36 psi Rear
Hope this helps.
Kev 8)
Crikey :roll: where did this info come from :?: Probably the English Cricketer’s dressing room during tactic discussions.
Mazda, you know the one who spent millions of $$$ developing the MX-5 and consulting with tyre manufactures, gives the recommended pressure at 28 or 29psi depending on the model. This gives the best ride, tyre wear and handling combination for the MX-5.
Now before everyone screams Mazda recommends those the pressures to suit a “comfortable” ride and not performance driving look again at what I’ve said.
If you want to move towards performance then increase the pressure, BUT only by about 2 psi. Keep in mind that when the pressure goes up, comfort and shock absorber life decreases and inner tyre wear increases.
For the track, raise the pressure to about 35 – 37psi cold. NEVER EVER let the pressure get above 41psi hot. Performance drops dramatically once this pressure is exceeded.
Also keep the front and rear pressures the same. The MX-5 has near enough to a 50/50 weight balance so front / rear pressure variation is not required for road use.
But back to your original query. As it’s 40 profile and not 45, put in 31psi and then fiddle up or down a pound or two to suit your requirements.
mickfred
Postby mickfred » Wed Jan 10, 2007 3:16 pm
Hey here's a thought.....
How about using the recommended settings? :P
YEAH BABY!
ducktape69
Postby ducktape69 » Wed Jan 10, 2007 4:53 pm
thanks a lot charlie brown... always good to hear from experienced mx5ers....
i changed the PSI from 27 to 35psi COLD this morning.....ill probably drop it to 31 as it feels a bit harsh for normal driving.
Users browsing this forum: No registered users and 153 guests
