PT wrote:You Have PM.
Or will do in about 2 minutes.
Dito.
Thanks for organising this and look foward to recieving it.
saboteur wrote:I've received payment and an address from blackster (thanks for that), is C+C happy to pick his up from blackster's place?
blackster wrote:Have spoken with C+C and his happy to pick it up from me. If your going to use regular post when sending from brisi to syd, can we please organise it to be registered with insurance.
blackster wrote:Out of curiosity is ken/aric offering insurance from the US to brisi?
saboteur wrote:Thanks guys I have all the confirmations from you.
This is a really good point, I'm not sure if it includes insurance but I will confirm this before placing the order.
PT wrote:Wow, that was quick and easy... well done guys... most group buys I've ever seen they take weeks and months to get the funds together, and then most people never put their money where there mouth is.
The MazdaSpeed Miata's IHI single-scroll blower produces 8.5 psi of boost to increase power from 142 horses to 178, and torque rises from 125 lb.-ft. to 166. Mazda also added a larger radiator, beefed up the engine mounts, modified the pistons, revised the camshaft, added Denso iridium spark plugs, and topped everything off with a red wrinkle finish valve cover for visual flair. The six-speed manual transmission also gets attention, in the form of more aggressive gear ratios, a stronger clutch and propeller shaft, and a shot-peened linkage for more satisfying shifting. A Bosch torque-sensing limited slip rear differential comes standard on the 2004 MazdaSpeed Miata.
THE REAL BORIS wrote:121 kw is M*zd* bullsh*t. My SE was no different to any MSM stock when dyno'd at 108rwkw at Chiptorque (145 rwhp). That's typical for all the SE's I've seen and typical FM/Begi figures for the MSM's. My car was only weeks old for that figure too. 8.5psig is journo-speak, not typically off the dyno. Incidentally, my stock boost was 7.3psig.
I get no boost creep. The only thing I have had to do is turn the boost down with the onset of the English winter. Now temperatures have flattened out, my mbc has not been touched for a month and no boost cuts. It's my firm belief that changing the inlet system leads to these problems and it's why I have steered away from it.
SMB, didn't they claim 13psig on a "stock ECU" when they were experimenting with Randy's car??????!!!! You have to read between the lines sometimes. http://www.smb.net.au/research.htm NOT sure who SMP is, but early Mania claims were, shall we say, optimistic.
I am NOT criticising just IMHO & what suits me & possibly C+C. I chose the FM because I believe what they have to say is supported and well documented and not been shown to be otherwise. The 2.5" pipe is just fine and a significant improvement over the stock 2.25"; it's stainless and rugged.
PT wrote:I have emailed off our order guys, just trying to ring through the credit card numbers... not going to email them or leave a message on their answering machine.
