Project: MegaSquirt build
timk
Postby timk » Sun Jan 07, 2007 10:24 am
Fatty has purchased it from me since I bought an SE, I don't really have a need for it at the moment! :P
blackster
Postby blackster » Sun Jan 07, 2007 11:11 am
saboteur wrote:Fatty has purchased it from me since I bought an SE, I don't really have a need for it at the moment! :P
Hats off to you for going to the trouble of making a standalone ECU, was it something that you could of not used on the SE, considering that the PTCU on the SE is rather conservatively tuned and bottled with limiters?
Previous
04' MX5 SE.
02' MX5 Classic ed.
timk
Postby timk » Sun Jan 07, 2007 6:00 pm
blackster wrote:Hats off to you for going to the trouble of making a standalone ECU, was it something that you could of not used on the SE, considering that the PTCU on the SE is rather conservatively tuned and bottled with limiters?
I could use it, but I'd need to fit an NA CAS. It's something I might do down the track but for now I'll stick with the basic mods. Changing the ECU or injectors is most likely years off. 8)
Fatty
Postby Fatty » Sun Jan 07, 2007 7:21 pm
might be easier / cheaper to fit bigger injectors and a dfa instead of a megasquirt. seeing as how the stock ecu should still handle all the spark stuff ok (as in, it's already coded for boost). might be wrong tho, just throwing it out there for you to think about.
i really should get onto finishing the megasquirt off. i must admit i haven't even openned it up since i got it from you :roll:
anyway, when it's done i'll post on this thread and give my thoughts on it.
