Help! Removing brake disc
Slugoid
Postby Slugoid » Tue Jan 02, 2007 3:14 pm
Hi,
Just wondering if you have any pointers into removing the front brake disc? I've unbolted the calliper already and the disc just doesn't want to come out. Anything else I need to unbolt?
StanTheMan
Postby StanTheMan » Tue Jan 02, 2007 3:30 pm
Whack the crap out of it.
I used a heavie hammer & a piece of wood to soften the blow on metal to metal
whack it, but be sensible about it
AJ
Postby AJ » Tue Jan 02, 2007 3:31 pm
decent size rubber mallet is a better option, & yes, bang the crap out of it 8)
XMX5 Rogues
green_comet
Car Detailing Guru
Postby green_comet » Tue Jan 02, 2007 3:47 pm
...what they said
Moggy
Postby Moggy » Tue Jan 02, 2007 4:48 pm
Get a 10mm bolt and screw it into the little hole on the brake disc between the wheel studs. Keep tightening it and you'll hear a 'crack' and the disc will come off. :)
Slugoid
Postby Slugoid » Tue Jan 02, 2007 5:13 pm
So it should come out without the need to remove the center bolt/bearing thing?
CT
Postby CT » Tue Jan 02, 2007 5:24 pm
Yes - no need to pull the hub bolt - use the 10mm bolt method - the threaded hole in the disc is designed for it.
green_comet
Car Detailing Guru
Postby green_comet » Tue Jan 02, 2007 6:44 pm
Just smash it already... :P :mrgreen:
Slugoid
Postby Slugoid » Tue Jan 02, 2007 7:11 pm
green_comet wrote:Just smash it already... :P :mrgreen:
LoL :lol:
I used the 10mm bolt method and the disc was out in no time :D . Thanks a lot for the advice. I think the disc hasn't been out for the odd 17 years of it's life cos there's so much rust and crap at the back :lol:
PS: Don't know how I'd live without you guys, haha! Else I would have been trying to get the hub bolt out with a 29mm socket and a huge breaker bar :shock: . I've had many mechanical problems that was all solved here as well. Cheers! Aus-cartalk FTW!
Boags
Postby Boags » Tue Jan 02, 2007 9:03 pm
I'm really glad to see everything went well! I take it you are installing the bigger stuff (i think it was you who bought Matty's stuff?).
I just have one question though... :oops: What does FTW stand for? I'm usually pretty good with these, but I can't figure this one...
Boags :lol:
Slugoid
Postby Slugoid » Tue Jan 02, 2007 9:12 pm
Na, I didn't buy Matty's good stuff, but i know who has them :P I think he needs it more than me since he has a turbo NA6 which was running on NA6 brakes :shock: . I'm just getting my discs machined, so that I can put some Hawk HP Plus pads on :).
FTW = For the win. Just a funny acronym that's been going around for the past year in other forums I go to. There's also FTL, which is 'for the loss'.
Boags
Postby Boags » Tue Jan 02, 2007 9:15 pm
Ahhhh, yes, I remember who it is now. And thanks for the explanation... :oops:
Boags
AJ
Postby AJ » Tue Jan 02, 2007 9:18 pm
Boags'MX5 wrote:Ahhhh, yes, I remember who it is now. And thanks for the explanation... :oops:
Boags
it's in the book boags
right under "E is for empty" :lol: :lol: :lol: :lol: :mrgreen:
XMX5 Rogues
Boags
Postby Boags » Tue Jan 02, 2007 9:29 pm
Boags
:lol: :roll: :oops: Like my avatar AJ? :P
Users browsing this forum: No registered users and 223 guests
