konis back in, but not right.
I've taken the flex out and reinstalled the konis but the left rear is sitting higher than the right rear, took it for a spin but its still the same??
- fastfreddygassit
- Waitin' for a mate
Re: konis back in, but not right.
mossy wrote:I've taken the flex out and reinstalled the konis but the left rear is sitting higher than the right rear, took it for a spin but its still the same??
Ican't see why it would have changed but are the spring perch heights the same? (there are 3 settings)
And possibly the springs (or even the dampener) aren't seated correctly?
- meanmx
I had that happen to mine and I think the sway bar shifted to the side a bit. A wheel alignment fixed it all up.
Ben
Ben
2014 VW Mk7 Golf R
- Mr Starlet
