Hi anyone got an easy way to fix this problem? The front face of my dash is separating from the horizontal surface of the dash. It is not that bad at the moment however it will not simply slot back in and the orange insulation foam underneath looks really ugly. Any ideas???? Anyone tried glueing it?
Thanks
Dan
Fixing dash pad/board separation
- StanTheMan
- StanTheMan
Spranga wrote:StanTheMan wrote:I replaced the whole dash
I was hoping no one would say that... but thanks for the advice anyway Stan.
Mine was cracked. So there was probably a bit more incentive to go the whole hog.
- Benny
fixing dash pad board separation
Hi Spranga
Mine was not separating but did have an annoying squeak. I managed to pull it away and the rubberised glue that had been used had hardened.
I used a black goo called bostik gold flex with a caulking gun (you can probably find something cheaper). Got to take care pulling it off though especially at the end near the steering wheel.
NB SE, NA 1.8.
Re: fixing dash pad board separation
trader wrote:Hi Spranga
Sounds like gluing can work
Thanks for the advice.
Dan
- lowmiata
can be easily fixed
If you know a trimmer or are good with a sewing mahine you can make up some piping which you can then squeeze in under and above in the join will take a while to do the whole dash though
I plan on doing this in the near future as mine has done the same
or I could just put the NB dash in!
EVI15 1998 to 2008
