Grinding Noice On Clutch Application
JBT
Postby JBT » Thu Dec 28, 2006 12:47 pm
Worn throwout bearing. Sometimes called a clutch release bearing. Works like this. Normally part of a clutch kit.
mightyrollaman
Postby mightyrollaman » Thu Dec 28, 2006 1:24 pm
JBT wrote:Worn throwout bearing. Sometimes called a clutch release bearing. Works like this. Normally part of a clutch kit.
Here, here. Also known as a thrust bearing. Best to replace the clutch while you've got it all apart.
The Rolla is mightier than the sword.
OMY005
Postby OMY005 » Thu Dec 28, 2006 4:06 pm
Don't forget to replace the spigot bearing as well while its all apart.
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Users browsing this forum: Bing [Bot] and 9 guests
