Rear Camber
Rear Camber
Hi All
Just noticed that the rear camber is slightly different from side to side, I'm concerned that ther maybe a worn bush or something that's causing it.
Anyone know the standard specs?
Graham
- Garry
- deez
- deez
rodent wrote:How much more camber is there to one side and where did you get it done?
Around -0.5 to -1 more on the driver's side. Don't have the sheet with me right now but from memory that's about what it is. Is that a stuffup? I was thinking it may be normal if there was more on the LEFT hand side, since the alignment has to compensate for the driver's weight. But not on the right hand side....
Got it done at Spinning Wheel in Woollomooloo after researching on here
89 Eunos Roadster
- Garry
That doesn't sound right Deez. Maybe you are misreading the alignment sheet?
Go back and have a chat to Stu to see whats happening, especially if your not happy with the handling they've dialed in. They have been very obliging to me in the past and have changed stuff when I wasn't happy with their initial setup. But dont wait to long.
- deez
- Garry
- deez
Garry wrote:That doesn't sound right Deez. Maybe you are misreading the alignment sheet?
Went home and read through the sheet again. Lucky I did so before calling Stu. Indeed I misread the sheet lol. Sorry guys
It is 0.08 more negative camber on the front right compared to the front left, and 0.18 on the rear right compared to the rear left.
Does that sound normal?
89 Eunos Roadster
- Garry
- Charlie Brown
I wondered about the difference between the left and right also the first time Stu set up my MX5.
Next time in I commented on the difference and following the alignment he had me get into the car. The readings came back to match left and right.
So the miss-match is just an allowance for driver weight. Mind you I have mine set up for track work not just road use so numbers will be different.
As for knowing his job, most of the quick Club cars use Stu to align their cars.
The results speak for themselves.
- Charlie Brown
kev.yan wrote:the camber will be even worse with the weight of the driver. As the lower to car the lower the camber.
I thought it would have been that way too but the alignment machine proved that it's the other way round when I got into the car.
A quick check of my sheets show 0.2 degrees more negative on the driver's side front and 0.3 more on the rear than the passenger's side.
- deez
Mine's similar...it goes against logic doesn't it? You'd think with the driver in the car you would end up with even more negative on the driver's side
89 Eunos Roadster
