Engine Swap
- green_comet
- Car Detailing Guru
- zoomzoom
- Vehicle: NA6 - Turbo
as far as I am aware(dont quote me) they are all based on the same ford duratec family of engines found in many 4cyl fords and mazdas, including Focus, 3, 6 and the new mx-5 \"MZR\" engine. Have a look on this site http://www.flyinmiata.com/video/others.php and click the link to the mzr video, its amazing to watch.
- Boags
Turbo the engine you have. Far less cost and heaps of power.
Unless you are in Adelaide where it is impossible to do so legally... Then use the search button, there have been a few threads about it lately.
Boags
Boags
- adamjp
- timk
Some guys in the US have used the Mazda FE van engine with good results:
http://members.aol.com/solomiata/FE3.html
http://www.miataturbo.net/forums/vbgara ... iew&id=157
- zoomzoom
- adamjp
Sp23s are FWD...MX5s are RWD...
So are Mazda 323 / Ford Lasers and NA/NB MX5s, I don't see your point?
The engine block is common. The oil and water systems are common, but the external interfaces a little different. One can be made from the other.
IMHO a Duratech is a very good consideration for updating an MX5.
Adam
- sabretooth
- adamjp
The Duratec is found in the Ford Focus & Mondeo, Mazda 3, 6 and MX5 and the Volvo 4cyl & 5cyl models. I believe that it is also the donor block for some Mercury 4-stroke boat engines (v.strong conrods from this source).
A V6 variant is also available overseas, but I think it is exclusively FWD.
Almost certainly the only RWD variant is the MX5.
I am unsure what the new Diesel Mazda 3 and 6 are based on. But if the Duratec block, it would deliver some insanely strong conrods and extremely high-comp pistons (18:1).
Nice little backgrounder here.
Adam
- KIJIMA
By the time you had a SP23 engine fitted into your MX-5 $$$ you could have fitted somthing like an SR20 or a RB26
Either way whatever you choose, an engine swap will be dear.
I'd be leaving your donk where it lies, and getting your hands on a hairdryer to bolt on, pretty much the same advice boags offered.
P.S. Search is your friend.
Money can't buy Talent, but it can buy Horsepower and sometimes that's enough
- RobbieRat
Users browsing this forum: Bing [Bot] and 9 guests
