Intercooler kits ??????
I am requiring an Intercooler for a NA6 ???????
Are Intercooler kits available for the NA6 or is it possible to use a 2nd hand
SE Intercooler and associated piping to fit.
What are the plumbing options for the NA6?
Looks a little tricky to fit the plumbing in an NA6 with A/C.
Thanks for your help.
Regards
Regards
- Garry
Most are individually fabricated to suit the turbo/exhaust manifold you are using. If you are using a popular set up like the Greddy or AVO kit then you might be able to find something ready made but be prepared to pay for someone elses R&D expenses.
If you decide to design your own then I wouldn't bother with an SE intercooler. You can get brand new intercoolers from Ebay for next to nothing these days that are much larger than the oil cooler size the SE uses and seem to work fine.
Boyracer is using an Ebay intercooler on his SE race car. It looks like it was put there by the factory and looks about tripple the size of the Mazda unit.
- Boyracer
- MX-5 Encyclopedia
I am pretty sure this is the one I have on my car...bargain,and as Garry said it looks like it was made for the job....it's not huge but it appears to work really well.
http://cgi.ebay.com.au/CoolingPro-550x1 ... dZViewItem
- Boags
Boyracer - I take it Mania or some other reputable fabricator did your intercooler pipes for you? How much did it cost and what size piping did you use with that intercooler? I think the inlet/outlet on the intercooler is 2 and 1/4 inches...
Boags
Boags
- blackster
Boags'MX5 wrote:Boyracer - I take it Mania or some other reputable fabricator did your intercooler pipes for you? How much did it cost and what size piping did you use with that intercooler? I think the inlet/outlet on the intercooler is 2 and 1/4 inches...
Boags
I believe the stock intercooler pipes on the SE are 2inch and what boyracer has done is just cut the existing stock SE pipes to fit the new cooler and attached it with silicons flanges.
Please correct me if im wrong lou.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Boags
- Boags
I just found a link to this.
http://www.mx5projects.com/Greddy%20Intercooler.asp
Fits with aircon and all.
- jules
- Guitar Hero
- Boags
I may be interested in selling my intercooler and associated plumbing/blow off valve early in the new year.
Will be complete with a bar and plate intercooler, stainless steel pipes and a GFB blow off valve. It is for a 1.8 using a avo manifold. Probably sell the turbo and manifold with it if someone wants the lot.
Jake
Jake
- blackster
C+C wrote:just a question on the ebay intercooler.
the size is 550 x 140 x 65. Is this the size that some of you guys have used?
This is what boyracer is using.
If so then it is different in dimensions to the IC used by Flyin Miata 19" x 8" x 3" ( or 418 x 176 x 55 cm). It is obvioulsy wider, yet slimmer. Does this matter?
Tricky, theoretically the ebay cooler compared to the SPM has greater surface area exposed because of the shape of our spoiler which would mean better cooling. However my concern is if the volume of the ebay cooler is greater then the SPM cooler then the onset of boost would come on later. Why? With more volume without an increase in pressure/boost, it would take longer to fill the cooler taking longer for air to reach the throttle body.
Does it need any special brackets?
Yes
Who can install it? mania or another fabricator?
Yourself if your pretty handy
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Sean
