I have my shocks and springs, now I want some whiteline swaybars to complete the package for my NA6.
Can anyone reccommend any diameter swaybars? I want to get adjustable bars and was looking at maybe 24mm front and 16mm rear. Is this over kill?
Appreciate any suggestions
Tim
Whiteline swaybars
- zoomzoom
- Vehicle: NA6 - Turbo
- RobbieRat
I'd have to disagree with that spin city comment. I have the same sways set at the same settings, and it takes effort to get the arse out, and i know cause i drift it. Id say the spnning bit would have more to do with your alignment and shock/spring combo in addition to the sways but def not the sways by themselves.
QR comming up to turn two top of 3rd, change to 4th and then i have to scando to get it out. I have 6 speed with 4.3 diff, and a turbo. Without the scando all i'd get is understeer at about the half way point of the turn. Backing off will just let me slow down and regain front grip.
Car setup: -2.5 cam & +5.5 cas & 2mm toe out, rear -1.75 cam 0 toe. Suspension tien type NA non adjustible at all - too soft for serious drift/track work.
But hey thats just me
Dave
Dave
Sway bars act as a spring between the two sides of the car, effectively resiting body roll. Essentially it will force the weight to distribute more evenly across both sides on the car under cornering. The stiffer/larger the diameter of the sway bar, the less body roll the car will experiance and the more evenly the weight will distribute. Keep in mind that although the suspension is now tied together, the chassis will start to flex more. Like everything, there is a balance between too much body roll and not enough. Your car needs to flex/roll to mobilize the suspension and make the most of your castor, etc, in order to get the maximum grip during cornering. This is where a sway bar can help.
Butters has Teins SS in a NA6, and they made a great difference to overall handling with the stock sway bars, however, you could still get it to slide around without much effort. With the addition of a pair of whiteline bars, the suspension really started to lock down, body roll dramatically reduced and cornering stability and turn-in went from \"pretty good\" to \"FRIGGING AWESOME\"
Basically in my own opinion the sway bars were the best bang for buck suspension mod you could do!
Now driving a Grand Vitara whilst waiting for the elusive Black SE
Users browsing this forum: Bing [Bot] and 3 guests
