Postby maxwolfie » Tue Nov 21, 2006 10:45 pm
Is there a way to \"tighten\" down the roof on the NA6, basically the connection points between the roof and the windscreen are starting to rattle against each other pretty bad on the drivers side. the \"clamp\" on the roof itself is screwed in tight to the roof frame, and the \"catcher\" on the windscreen is also tight
It's a little hard to explain
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
