Offset ... need help. Will this wheel fit an NA
- JSE
I would like to know what the maximum/minimum offset of a wheel that will fit onto a stock NA6...
I am looking for new wheels but I am not sure if they will fit due to the offset and all that jazz since they have a fair bit of dish on them...
Thanks in advance
Thanks in advance
- JSE
http://www.bsawheels.com.au/users/ProductDetail.aspx?id=353
these are the ones I'm looking at in 4 or 8hole...
would they fit on a NA6 with king springs and KYB AGX adjustables???
- Garry
The wheels don't have a large 'dish' as the offset says 35/45 it is the spokes that have a large curve in them thus allowing a large 'lip' with the appearance of a large 'dish'. Hope this helps.
Andrew.
Andrew.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
- Mr Starlet
kitkat wrote:i can fit 15 x 7 15mm offset, wrapped in 195/60 yoko's on our NA6, its dumped on LOW espelir springs... i had no problems
hmmm...just measured the old school looking rims sitting in the shed, 15x7 +9 offset on 195/50, I too wonder if these would fit on a stock NA with stock camber. My feeling is no but would be good if someone could clarify. Cheers Minh
- StanTheMan
I think they'll look quite good. However looks are very subjective.......especiallywith the subject of wheels.
Our pommy friend from MX5Nutz.com had some very dischy wheels. 35mm offset. Best dischy wheels i've seen personally.
also check the weight. how heavy are those things.
spacers......gawd getting better every minute......may i suggest you get your No plate off your sig.
- RaYmO
StanTheMan wrote:I think they'll look quite good. However looks are very subjective.......especiallywith the subject of wheels.
Got pics of the dishy rims?
- StanTheMan
- RaYmO
- StanTheMan
