Can you get decent dodgy alignment?
- roddclarke
You should just give it a go...
I have done many a car with a string line.. just as acurate as any of the latest equiptment.. just takes a bit longer to set up.. and measuring the caster is the hardest part..
but its fun and exciting to know you did it yourself
but if your going to a workshop.. i take mine to Jax Stmarys.. $70 and a good job too
"If your in 5th, your not having fun"
1:13.26 at Wakefield, 52.92 at OP south, 1:25.97 at OP GP, 1:56.78 at EC.
previously 2002 Supreme Blue... now 2001 Crystal Blue...
Ralphie, I've PM'ed the price. Here's the background to it.
I'm trying to run in clubman class on stock springs and stock 14x6 wheels with street tyres. They weren't too sure about how to set up race handling for such a stock setup.
I figured that it could easily take two alignments to do it, so I'd probably end up in front and I'd have some input into what was being done. Maybe you'll find someone who knows straight out what's best for your setup and needs and get it done just once for $90 or so. I don't know.
The race handling was atrocious before, no grip, terrible oversteer, mainly due to zero and even positive cambers. He's taken it to 5.30 castor and -0.5/-1.0 camber F/R as the first step, saying he knows that's pretty mild but I should drive it like that for a while first, get the feel of it and then come back and talk. I wanted to go to around -1.5/-2.0 but he reckoned it's better to test it in stages. I can handle that because they're 5 minutes drive from my place and you get to check all the other cars there.
