SE Brake Bleed Order
Postby Okibi » Mon Nov 13, 2006 5:01 pm
Does anyone know the order in which you bleed the brakes on an SE (ABS)?
irwin83r
Postby irwin83r » Mon Nov 13, 2006 5:32 pm
i thought it was always furtherest from the master cylinder first?? soo.. back left the back right etc??
why it differ ABS or no ABS?? (not being a prat, just want to know :D )
CT
Postby CT » Tue Nov 14, 2006 9:34 am
Rear Passenger
Rear Driver
Front Driver
Front Passenger
Ignition shoud be switched to on and ideally done with a vacuum pump but the old fashion system works OK too. Order is longest lines to shortest lines.
jules
Guitar Hero
Postby jules » Tue Nov 14, 2006 4:42 pm
Would this be the same for NA's?
Jules
Boags
Postby Boags » Tue Nov 14, 2006 4:50 pm
Yep.
irwin83r
Postby irwin83r » Tue Nov 14, 2006 6:27 pm
wouldnt the front passenger side be longer than drivers on NA and/or non abs cars?
CT
Postby CT » Wed Nov 15, 2006 9:05 pm
Only for ABS cars - Irwin83r is right - swap to passenger front then drivers frontfor non abs cars. 8)
Users browsing this forum: Google [Bot] and 6 guests
