hundred buck blocker
davamb
Postby davamb » Mon Nov 06, 2006 10:14 pm
Though about doing this for a while and finally had a free day to knock it up.
Here's a pic of the results, not too shabby:
Bought the lexan from Buntings, the edging from Cluck rubber. Change out of $100 and very happy with the result. Held on to the strut brace with pipe clamps which have been sheathed in heat-shrink plastic.
And the template:
Anyone wants a loan to roll their own, you're most welcome. Just trace it out, then cut very carefully with a jigsaw.
Cheers, Dave, 1990 NA6
Via est vita.
davamb
Postby davamb » Mon Nov 06, 2006 10:16 pm
Dang. Where are my pix?
Via est vita.
STV
Postby STV » Mon Nov 06, 2006 10:19 pm
could you PM them, or email em to me?
Thanks
STV
Where is 'Home Sweet Home'?
Craig
Postby Craig » Mon Nov 06, 2006 10:22 pm
Needed .jpg on the end of the filename! :mrgreen:
davamb
Postby davamb » Mon Nov 06, 2006 10:25 pm
Thanks guys,
It does look a bit better in real life. The missus thinks I slipped out today and blew double that on manufactured items! (That's really flattery now I think of it.)
Via est vita.
davamb
Postby davamb » Thu Nov 09, 2006 9:59 am
Anyone interested if I knock up a couple more?
Via est vita.
Boags
Postby Boags » Thu Nov 09, 2006 11:25 am
I got a factory one for $150 I think. The reason I didn't go one of those is because I thought it would make puting the roof on and off impossible from inside the car. Is this the case?
Boags
Fatty
Postby Fatty » Thu Nov 09, 2006 12:14 pm
i'd be interested but i need to get the brace to fit it onto first.
don't suppose you have a spare one of those lying around do ya ?
Gramps
Postby Gramps » Thu Nov 09, 2006 3:05 pm
davamb wrote:Anyone interested if I knock up a couple more?
I see a bit of a problem putting up the top while sitting in the car. Do you have to get out to do it - or does it just swivel on the tubing and lay flat ?
"When you're racing against Father Time drive a 5!"
bigdog
King of the kennel
Postby bigdog » Thu Nov 09, 2006 4:48 pm
no different to having a BD bar - you reach back over your right shoulder and pull the roof up by the frame until you can grab the centre handle. Takes a little practice and easy to dislocate your shoulder, but can be done :D
davamb
Postby davamb » Fri Nov 10, 2006 10:01 am
I designed it to clear the softop, and it's kind of handy being upright when you stow stuff behind it, it doesn't come flying forward when you emergency brake. Still you do have to reach over it to raise the top. It will swivel on the brace, but you need to loosen off the nuts a tad first, and the seats would have to be further forward to clear the underhang bit. Maybe wingnuts would be a better choice here (I was going to get some domenuts over the weekend).
I'll do a detailed costing exercise tonight and see exactly what it cost me in materials, I think it's a lot less than $100, but I couldn't make good use of the lexan sheet I bought, just can't get 2 cuts to the sheet - there may be better options here, other than Buntings standard cuts.
Via est vita.
