15\" JDM look...how to?
Babalouie
godfather of saké
Postby Babalouie » Fri Nov 03, 2006 5:38 pm
deez wrote:
Babalouie wrote:
Guard rolling isn't expensive....I paid $25 per guard, but make sure the guy who does it is good tho...I've had jobs on other cars done which were shockingly poor.
Thanks for the suggestions :) Can you recommend a good place for guard rolling in Sydney? Thanks.
Actually no...the guy did a great job on my MX5, took his time, got each side looking the same, etc, but when I took my other car to him, he was in a hurry, started bashing the guard with a hammer, etc :(
So yeah, if you find a good place to get it done, let me know, I'm on the lookout too :D
irwin83r
Postby irwin83r » Fri Nov 03, 2006 6:11 pm
EGG80X wrote:here are some eudm dish....
25 Offset on 7" wide rims running 195/55r15
no scrubbing at all.....
thats only because its running the 4x4 suspension. :D
damn dish looks sexy though..
15x7's will be fine i'd go 205... the wider you go the better it looks. 215 would be widest legal and prolly in my opinion best looking.
i did run 225's looked great felt bouncy and squirmy. but couldnt damage my rims even if i tried and looked PHAT as!! :D
it really depends what look your after.. you can go narrow ruber to get the drifto look where the sidewalls tapper in wards slightly.
or like i tend to go the phatt racey look with the widest rubber you can get on to small diameter rims.
if your having trouble getting your melon round all the numbers go to this site
http://www.1010tires.com/tech.asp
and have a wonder. theres all you need to know and alot of handy tools to use when checking sizes.
as far as i know with legality its basical 1inch wider max width, rolling diameter (not rim dia) and 50mm wider track (1 inch a side offset sorta kinda)
correct me if im wrong ppl.
green_comet
Car Detailing Guru
Postby green_comet » Fri Nov 03, 2006 6:53 pm
watanabes here with 14x6.5 +14 offset..
irwin83r
Postby irwin83r » Fri Nov 03, 2006 7:20 pm
Mr green.. thats one sexy clubmen. you have a cardomain page?
Adam_NAclubman
Postby Adam_NAclubman » Fri Nov 03, 2006 7:36 pm
We all have sexy Clubman's :P
+45 is only the standard offset on the standard narrow wheels
I rolled my guards on the side of a country road with a thick branch from a tree, worked really well, no paint damage at all. It was only after we got back and decided to go over it with a pipe (even rolled in rags) that we cracked the paint straight away
15 x 7 + 17 with 195/50/50's
http://i47.photobucket.com/albums/f152/ ... 220103.jpg
15 x 7 + 17 with 205/50/15 semislicks.... Don't even think about it
irwin83r
Postby irwin83r » Fri Nov 03, 2006 7:39 pm
and i thought my front bar needed a respray :shock:
Adam_NAclubman
Postby Adam_NAclubman » Fri Nov 03, 2006 7:55 pm
Umm... It IS getting a respray
Flat white Clubman. Rubbed it back the other day. Paint was all screwed from a close meeting with a wire fence courtesy of my cousin
zoomzoom
Vehicle: NA6 - Turbo
Postby zoomzoom » Fri Nov 03, 2006 8:14 pm
Hi deez, im pretty new to this forum too so welcome fellow newbie :D I also have an na6 and am running 15x7's with a +35 offset. with 205/50R15 potenzas under std guards and havn't had a problem either. Just thought I would throw my 2c into the conversation :D
green_comet
Car Detailing Guru
Postby green_comet » Fri Nov 03, 2006 10:35 pm
irwin83r wrote:Mr green.. thats one sexy clubmen. you have a cardomain page?
thanks m8, i dont have a car domain page.. I should make 1 up though.. give me a couple weeks and ill make one.. :D
deez
Postby deez » Sat Nov 04, 2006 1:05 am
zoomzoom wrote:Hi deez, im pretty new to this forum too so welcome fellow newbie :D I also have an na6 and am running 15x7's with a +35 offset. with 205/50R15 potenzas under std guards and havn't had a problem either. Just thought I would throw my 2c into the conversation :D
Hi mate, good to see a fellow newbie! And thanks for all of your response as well guys. Zoomzoom, can you pls post some pics of ur ride? I'm interested to know what the 15x7's with +35 offset looks like as that would *probably* be close to the configuration I'll end up with.
Thanks !
deez
Postby deez » Sat Nov 04, 2006 1:08 am
Adam and GreenComet.....your cars look AWESOME. Oh man.....I really do gotta consider rolling the guards. On the other hand, I don't really want the hassle of doing so....Christ....what a predicament!
Adam_NAclubman
Postby Adam_NAclubman » Sat Nov 04, 2006 1:11 am
2 inch diameter, 18 inch long branch. Get a mate to rest it on the wheel and lean on it, then you move the car forwards and backwards. As long as you do it gradually enough, and the wood is still green, it won't harm the paint at all
Postby bruce » Sat Nov 04, 2006 1:02 pm
I think hot paint is more flexy (soft) so less likely to crack than cold paint. Hit the guard with a hair dryer for a while or heat gun (careful it will bubble the paint if you leave it too long).
deez
Postby deez » Sat Nov 04, 2006 6:58 pm
Guys,
I went to JDMyard in Padstow this arvo....checked out some of their range and seemed that Buddy Clubs are quite nice and relatively inexpensive. I was looking at a set of 15x7\" SF's and the guy told me that the max offset I can get for those rims are +35 :?:
How did u guys achieve +15 or +30 with your rims??
Adam_NAclubman
Postby Adam_NAclubman » Sun Nov 05, 2006 1:37 am
I've got 15 x 7 +17 BuddyClub P1's, I think they came on a import from Japan.
How much were new SF's?
Users browsing this forum: No registered users and 137 guests
