What aftermarket seats have you fitted? now with pics
- bigdog
- King of the kennel
It won't work Matt... You'd need to be under 170cm tall to fit under a BD bar. Go to Mania and have a sit in their race cars and do some measuring from the top of the seat belt tower to the top of your head - this will tell you how much lower their various race seats are than your existing seat. I would be very surprised if you could get under the BD bar by 50mm in any seat. Your only possible solution would be to get a custom bolt in bar made that had enough height, weld in the mounting plates and nuts so you can unbolt it for daily use, then bolt it in for CAMS events. Don't forget to include a forward brace to the passenger's floor/tunnel too.
- ASE05
Woooooo Hoooooo!
Just finished the fitment of..........
- Boags
Pics didn't work for me ASE, anyone else have the same problem?
Boags
Boags
Boags'MX5 wrote:Pics didn't work for me ASE, anyone else have the same problem?
Boags
cant see pics
EDIT : even if I copy and paste the properties of the image I cant see the pic ... seems to have moved or doesnt exist anymore ???
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
If you can see them try here:
http://pics.aus-cartalk.com/qldclub/ASE05/
- ASE05
- bigdog
bigdog wrote:It won't work Matt... You'd need to be under 170cm tall to fit under a BD bar. Go to Mania and have a sit in their race cars and do some measuring from the top of the seat belt tower to the top of your head - this will tell you how much lower their various race seats are than your existing seat. I would be very surprised if you could get under the BD bar by 50mm in any seat. Your only possible solution would be to get a custom bolt in bar made that had enough height, weld in the mounting plates and nuts so you can unbolt it for daily use, then bolt it in for CAMS events. Don't forget to include a forward brace to the passenger's floor/tunnel too.
wooot i'm 167cm tall
My Sparco sits a little bit lower than the stock seat too......
- ASE05
bigdog wrote:How did it mount ASE05? can you supply some measurements across the lower part of the back (between the side wings)? I looked at Cobra seats and had settled on the Imola II - is the Monaco smaller or larger?
Looks great and is obviously better made than the OBX in mine... I'm jealous!
I mounted a 6mm alloy plate to the base of the seat and used another couple of 6mm plate strips as spacers to mount to the rails. Unfortunately I'm at the same height I was before if not a lil' taller. I'm gonna rip it back out though and mod the plate so I can remove the spacers. If that works out OK, I'm gonna order the 1cm lower rails.
As for how big compared to the others you have mentioned......wouldn't have a clue!
Dims are here:
http://www.cobraseats.com/motorsport/monaco.php
If that's noty enough lemme know and I'll get the tape measure out on the w'end.
- adamjp
Using the OBX designated measuring points on my Cobra Monaco S seats.
You can see the offset that I used to fit my Monaco S drivers seat in the attached photos.
By offsetting the back a bit towards the trans tunnel, I was able to get the seat to clear the 'B' pillar area of the car. And the seat still goes back and forward to adjust between myself and the missus.
Love the Monaco S, great seat, very comfy and fits my big ass with room to spare.
- A = 560
D1 = 330
D2 = 470
E = 510
Adam
Users browsing this forum: Bing [Bot] and 0 guests
