Quick question.
A friend of mine has an NB8 (C I think) and one of her soft top latches isn't working properly - apparently it takes a few goes before it actually latches.
Is this a common problem?
She's been quoted $400 from a Mazda dealer for a new latch, which ... seems a little over the top.
Are the NA and NB ones compatible? I assume Mania would have a pile of them laying around?
NB/NA soft top clip compatibility
- kitkat
I'm pretty sure that they are basically the same. Having said that I know that many NBs were suffering from clips that were worn out and the latch could actually release, usually with the car in motion. Not heard of this being a problem on the NAs for some reason.
If you do a search on the big forum you should find heaps of examples.
J
J
kitkat wrote:when you say it doesnt latch, is it because its not catching?
I haven't had a look at it yet, but the impression I got was the it was latching fine, but not staying latched.
I was also under the impression that the adjustment only adjusted the tension on the roof, not the latching tension. I'll have a look when I get home.
- Garry
It's possible to file a few mm off a stopper on the latch mechanism so that the latch doesn't come unlocked by itself. Do a search through the forum for instructions. Much cheaper than buying a new one and not much more work than replacing it with an NA one.
I thought the latches were changed slightly in the last of the NB's so they are not quite compatable with the earlier ones
- irwin83r
