I ran 215/40/17 back and 205/40/17 front. Front scrubed with the 215's on the front.
rjr666 wrote:
kula wrote:ok,
i finally did a test fit with my WORK wheels..
15x8, +35.
195/50/15 rubber and it fits, but the inner lips seem to rub.
ill do a guard roll and i reckon it will be fine
they fill the guards brilliantly..
as soon as they are in, ill post pics:)
RaYmO wrote:Is 15x7 +4 offset going to be a bit too badass for the guards?
Sheck wrote:If you do a "proper" flare which is folding out the inner lip and rolling the whole thing (you may possibly need to cut and weld the gaurd to make it all smooth, but i'm not sure as i havent got a gaurd roller) then you can fit in a 15 X 7 +0 easily. Well no easily but the wheel will sit just inside of the gaurd and you wont/shouldn't rub.
How do i know this?
Well i'll get a photo of my mangled gaurd up soon, but just for shits an giggles (and to tet if a 0 offset rim would fit) i put my 25mm spacers on the front of my car with my +25 rims. I found that yes the wheel would rub but only when turning and if you dont have rock hard suspension![]()
But i flipped out the inner lip thingy and rolled it with just a bit of 2inch exhaust pipe off cut. The gaurd, if it was smooth, looks really nice and fits the wheels nicely ie they are filled.
My guard on the other hand is not smooth and looks terrible/mangled, but hey at least its only one of them and at least i know that my rim of choice will fit when i do get it eventually. Plus it suits the look of rest of my car![]()
Dave
