sagging help please?
Ralphff
Postby Ralphff » Wed Oct 18, 2006 9:53 pm
Help my car is leaning to the right! Can anyone advise whats wrong with my NA8, I’ve noticed in the last week my car has sagged 10mm on the front and rear RHS. I’ve also had a clunking noise at the front right wheel. I’ve pulled the front right wheel off and had a good look at the bushes, springs, shocks and ball joints and can’t really see anything wrong.
Are these problems likely to be related?
Should I take it to a suspension place?
Can anyone recommend a good workshop to go to?
Thanks for looking.
AL
Vehicle: NA6 - Turbo
Postby AL » Wed Oct 18, 2006 10:23 pm
Sounds like it's time for aftermarket springs and shocks for you i'm afraid. Plenty of options to suit your budget and requirements
Tinkered with 1991 NA6
Ralphff
Postby Ralphff » Wed Oct 18, 2006 10:29 pm
I'd like to lower my mx5, but preferably 30mm both sides not 10mm on one side. :shock:
Is this normal wear and tear for a na8 it done about 135,000km?
Russellb
RIP Nov 2014
Postby Russellb » Wed Oct 18, 2006 10:52 pm
After 215 000 km and I have no sag. even had it on the corner scales and
no major differance betwwen corners :)
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Ralphff
Postby Ralphff » Wed Oct 18, 2006 10:58 pm
Russellb wrote:After 215 000 km and I have no sag. even had it on the corner scales and
Didn't clubmans have a diffrent set up to the run of the mill NA8?
Russellb
RIP Nov 2014
Postby Russellb » Wed Oct 18, 2006 11:16 pm
I they have Bilstien shock stiffter springs( I think ) and a lower ride height (about 10mm) So Yes differant than your run of the mill NA8's
My ClubmanRebuild
JBT
Re: sagging help please?
Postby JBT » Wed Oct 18, 2006 11:22 pm
Ralphff wrote:I’ve noticed in the last week my car has sagged 10mm on the front and rear RHS.
Mine was like that when bought at 116,000km. Mostly one occupant in it most of its life so it had sagged a bit. A set of Kings springs fixed it.
Ralphff
Postby Ralphff » Wed Oct 18, 2006 11:28 pm
Did you replace the shocks as well? mine seem in good shape.
JBT
Postby JBT » Thu Oct 19, 2006 9:27 am
Replaced all the shocks with Koni adjustables about 2,000km later :roll: when one of the originals died. Do the lot at the same time if you can afford it because it's just as much effort (labour) to do it later.
Ralphff
Postby Ralphff » Thu Oct 19, 2006 11:29 am
JBT wrote:Replaced all the shocks with Koni adjustables about 2,000km later :roll: when one of the originals died. Do the lot at the same time if you can afford it because it's just as much effort (labour) to do it later.
I'd really like to fit tein SS's, but the bank account's at bit dry of funds at the moment. :(
Thanks for your help :mrgreen:
Richee
Postby Richee » Thu Oct 19, 2006 5:47 pm
Ralphff wrote:I'd really like to fit tein SS's, but the bank account's at bit dry of funds at the moment. :(
Save for the Tein SS, you wont regret it
Richard
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
irwin83r
Postby irwin83r » Thu Oct 19, 2006 5:48 pm
Ralphff wrote:Help my car is leaning to the right! Can anyone advise whats wrong with my NA8, I’ve noticed in the last week my car has sagged 10mm on the front and rear RHS. I’ve also had a clunking noise at the front right wheel. I’ve pulled the front right wheel off and had a good look at the bushes, springs, shocks and ball joints and can’t really see anything wrong.
Thanks for looking.
10mm... just on the right/drivers side you say??
hmmmmm
cut back on the beer and patato chips :P :wink:
im happy with my tien ss's. most other are. will you be able to fit them your self?
there are cheaper spring shock setups that arnt bad out there too.
Users browsing this forum: No registered users and 65 guests
