Timing Advance
- sabretooth
- JBT
rzzzwilson wrote:What *could* be the problem?
As Sabretooth said, the ECU could be holding it. You'd need to short the TEN and GND terminals in the diagnostics box to see what the base tming is.
rzzzwilson wrote:Mistiming the cams shouldn't affect the ignition timing?
Yep, sure can. We found a B6 engine with ignition timing of about 20+ degrees BTDC. Turned out that the mechanic who changed the cam belt set the intake cam (CAS cam for a B6) off by one tooth. We reset the cam to where it should've been, the timing came back to 10 degrees BTDC where it should've been and the overheating stopped happening.
- JBT
Sorry, you asked about cam timing vs ignition timing. I thought it was a general question.
Possible reasons I can think of for NB:
Crank angle sensor not properly seated/located/fitted
Crank angle sensor mounting holes elongated
Front pulley slipped - really bad news
Aftermarket ECU
Parallax error when reading timing
That's where it always was ex factory.
Aftermarket ECU
- Garry
- Garry
Users browsing this forum: Google [Bot] and 5 guests
