i currently have the 205/45 r17 from the NC mx5. Now i want to widen its track a bit to 215 but not sure whether to go 45 or 40 r17.
using the miata tyre calculator:
Specification Sidewall Radius Diameter Circumference Revs/km Difference
205/45-17 92mm 308mm 616mm 1936mm 516 0.0%
215/40-17 86mm 302mm 604mm 1897mm 527 -2.0%
215/45-17 97mm 313mm 625mm 1964mm 509 1.5%
So as you can see, at 100kph on speedo:
40 tire would actually be 98kph
45 tire would actually be 101.5kph.
which would be more suitable?
would ride compliance (e.g. comfort?) be affected if you go 40 vs 45?
also, any tires anyone could recommend around 200 mark? i got quoted toyo proxes 4 @ 180 each fitted or kumho ast @160. but they seem not so flash tyres.
upgrading to wider tyres?
- Black miata
Re Tyres for NC
I have just fitted 215 45 x 17 tyres to my NC and can give you the following information.
Speedo error is negligible.
Road Ride Comfort is sensational
Track work disappointing at normal pressures.
I have been experimenting and have found that 36 all roand still gives a nice ride and good handling but for the track I have been running at 40 psi. I am still experimenting with pressures and will post more infor as it comes to hand.
- Black miata
Re Tyres for NC
- Black miata
GoodyearRev spec F1
They are a premium Goodyear product, and perform brilliantly.
Users browsing this forum: No registered users and 36 guests
