Turbo - running in ??????
Do you have to \"run in\" new turbo's ???
Thanks
Thanks
- Russellb
- RIP Nov 2014
Don't think so
I have always put them in and run them at what ever boost I set. Never had a problem. Just do an oil change when you fit it and chage the il every 5 000Kms and all should be good.
My ClubmanRebuild
MX5 SE Rally car is HERE
- Garry
- Boags
I have read yes. The most important thing was that you don't run synthetic oil, and that you turn the engine over WITHOUT spark for 15 seconds to pump fuel into the turbo.
Then it said, no higher than 4000RPM for 300-500miles. This was for the TDO4 mitsubishi turbo on an MX5. I just googled it and couldn't find the page again, but that is what i remember it saying.
Boags
Boags
JBT wrote:Boags'MX5 wrote:The most important thing was that you don't run synthetic oil, and that you turn the engine over WITHOUT spark for 15 seconds to pump fuel into the turbo.
that's how u get the after burner effect
- Craig
- Vehicle: Non MX-5
Philip Lee wrote:JBT wrote:Boags'MX5 wrote:The most important thing was that you don't run synthetic oil, and that you turn the engine over WITHOUT spark for 15 seconds to pump fuel into the turbo.
that's how u get the after burner effect![]()
You just need StanThe Man in your car if you want an after burner!
I wouldn't bother, and I think who ever wrote that boags is full of sh!t.
You should certainly let a turbo warm up when you start the car just like a motor (IE don't go flat strap straight away) but I don't reckon when the bearings are spining that fast without much load that a \"Run In\" procedure is going to do much if anything.
'92, Red, Hardtop, Noisy CAI, Even more Noisy Exhaust, AVO Shocks with TJR Springs (Not so Fuli drifto speco).
doubt it since everybody else recommends running fully synthetic rather not just semi synthetic and since the big one to worry about in the bearings would be coking from overheating I would reckon the less crap in the oil the better... as such full syn should be better. But I don't know the exactly so I wouldn't take what I say as gospel, but I'd think twice before believe anything like don't use fully synthetic.
- JBT
- Garry
Except at the HSV bumper factory one of the first things they do (a few years ago, not sure about current practice) when they get the car from Holden is drain out the dino oil and refill with Mobil1. So the only run in the engine has done is driving on and off the truck. When asked about using fully Synth for running in the HSV tour guide said something along the lines of Mobil1 being the finest oil in the world, why use an inferior product.
- sabretooth
- fish
