Can you get decent dodgy alignment?
Mr Starlet
Postby Mr Starlet » Mon Oct 09, 2006 12:49 pm
Hi everyone
Is there any tips and tricks on getting a decent dodgy alignment on an NA. The MX5's got dials/markings for camber and possibly castors as well, how are these markings relate to actual value, given that the car is 100% straight (no past accident) could I reliably use these dials as reference?
From my previous dodgy alignments on the Starlet, I learnt that you first set castor to as much as you can but keep bothsides equal, then set camber; for best tyre wear, a bit of negative on the left and none on the right (to negate for existing road camber). The final and most difficult stage I found was toe, how do you know that you've got just the right static toe-in so that when the car is in motion the dynamic toe is zero?. Maybe I'll just dodgy castor and camber and let the shop do the final toe for cheap.
What do you recon would be the best tyre friendly alignment specs, mostly for everyday driving and the occasional twisties :D?. The best alignment shops in brisbane that I know of is Fulcrum, they'll do castor, camber and toe for both front and rear for $100. Pretty cheap considering what they do but that's still $100 I could spend else where like saving towards a set of Tein Coilovers, and that alignment might go out of wack once I machine the rotors, change the pads or play around with the suspension then I'll be up for more cost...the alignments for the Starlet definately builds in between suspension mods and tweaks. If I have the cash, I'd do all the suspension bits at once and get a away with just one alignment, but cash is the problem so gonna have to do abit at a time.
Anyway, any tip or tricks on DIY, alignment would be really helpful.
Minh
Postby Okibi » Mon Oct 09, 2006 8:58 pm
Sorry mate no DIY tips from me; I'd only ever use the experts.
The difference between an alignment and a GOOD alignment is noticeable.
rodent
강남 스타일
Postby rodent » Mon Oct 09, 2006 9:44 pm
Okibi wrote:Sorry mate no DIY tips from me; I'd only ever use the experts.
^Agreed. Being an FR car the MX-5 is more sensitive to dodgy alignment than an FF Starlet. Also, sudden unexpected oversteer is scary!
jonno.
JBT
Re: Can you get decent dodgy alignment?
Postby JBT » Mon Oct 09, 2006 11:20 pm
Mr Starlet wrote:a decent dodgy alignment
Mutually exclusive terms I'm afraid. :|
solo22
Postby solo22 » Tue Oct 10, 2006 12:22 am
So where do you dudes get the decent alignment done? (Melbourne)
I got one recently at Bob Jane (heh), I thought it was GREAT as I could feel the road now, but after a while I notice it pulls to the left, and when doing a fast turn I get some massive oversteer, a bit scary...
JBT
Postby JBT » Tue Oct 10, 2006 6:36 am
The general rule is to only go to a place that has competent operators and \"calibrated\" alignment equipment. Normally this will be a suspension/alignment specialist workshop. Most tyre dealers wouldn't have a clue or calibrated gear.
Postby Okibi » Tue Oct 10, 2006 8:08 am
Also good suspension workshops have much tighter tolerances than the “near enough is good enough” settings some tyre fitters/budget suspension shops use.
I’d pick a shop that the motorsport/autokharna people in your MX-5 club use, then discuss with them what your requirements are.
Mr Starlet
Postby Mr Starlet » Tue Oct 10, 2006 9:54 am
sabretooth
Postby sabretooth » Tue Oct 10, 2006 11:01 am
Alignment's one of those things I'd leave to the pros. Plus isn't an alignment only like $65??
Boags
Postby Boags » Tue Oct 10, 2006 5:44 pm
sabretooth wrote:Alignment's one of those things I'd leave to the pros. Plus isn't an alignment only like $65??
Yes, if you go to Beaurepairs or Bob Jane. A suspension shop like Fulcrum start at $100. It's $90 with club discount.
Boags
Garry
Postby Garry » Wed Oct 11, 2006 9:59 am
And one of the best $90 you can spend on your car. A good alignment will transform the handling of an MX5 in the same way that a bad alignment will destroy it. Find someone that knows what they are doing and get it done right.
Mr Starlet
Postby Mr Starlet » Thu Oct 12, 2006 6:52 pm
Garry wrote:And one of the best $90 you can spend on your car. A good alignment will transform the handling of an MX5 in the same way that a bad alignment will destroy it. Find someone that knows what they are doing and get it done right.
Any shop in brissy you would recommend?
Boags
Postby Boags » Thu Oct 12, 2006 7:13 pm
Pedders at Geebung did mine. A bit more than Fulcrum at $115, but the guy was awesome, and drove my car off the ramps and around the block 3 times before he was happy with the job he had done. A+
Fulcrum are also very reputable, and support car clubs, so you get a discount. I believe it works out at about $90. Again, these guys are said to do a good job, but I'm never organised to book an alignment in advance, so i always miss out at Fulcrum (3-4 day waiting period).
HTH
Boags
ralphie
Postby ralphie » Wed Nov 15, 2006 12:30 pm
can you recommend a suspension place in melbourne?
deez
Postby deez » Wed Nov 15, 2006 2:24 pm
Recommended place to get alignment done in Sydney????
THANKS! 8)
Users browsing this forum: No registered users and 124 guests
