Kings or Whiteline?
STV
Kings or Whiteline?
Postby STV » Thu Oct 05, 2006 4:09 pm
Howdy Folks
just cruisin the mania site last night and i saw how CHEAP the springs are for an NA!!
SO... if i were to replace the springs ONLY, not the shocks, what sort of ride could i expect?
Are there any problems with this setup?
What you you go for... The Kings ($150) or the Whiteline ($145) springs??
and is $150 a reasonable price for installation ??
ps. The car is my daily hack, probably wont hit the track :frown: , but sometimes dríven moderately hard..
Thanks and regards
STV
Where is 'Home Sweet Home'?
Garry
Postby Garry » Thu Oct 05, 2006 4:19 pm
If you fit lower higher rate springs at worst you need new OEM dampers, better still are dampers with damping that match the firmer springs, ie slightly less compression damping and much firmer rebound damping. Fitting firmer springs to 16yo OEM dampers will not give the optimum result. I think you would spend most of the time bouncing off the bump stops.
You would get a much better outcome keeping the stock springs and fitting new dampers than visa versa.
STV
Postby STV » Thu Oct 05, 2006 7:00 pm
Thanks Garry..
yeah, i didnt think it was the optimum setup, but i hadnt thought it would be bad..
Oh well... i guess i then save up for either kings and konies or kyb, or eibach..
Just means it is (much) further off, but i guess it would be more worthwhile in the end
Thanks for the heads up... without this place, i would probably have just gone and screwed my car up!
STV
STV
Postby STV » Thu Oct 05, 2006 11:54 pm
cool.
i will wait till i can afford the right stuff, and an convince the financ e dept that i NEED it!
thanks for the help guys
STV
Postby Okibi » Fri Oct 06, 2006 12:13 am
Go for the eibach or save a little longer and go teins.
pcmx5
Postby pcmx5 » Fri Oct 06, 2006 10:19 am
I have had standard springs/Koni;king/koni, Eibach/ koni and by far the best of those combos was the standard springs so I agree with Garry.
The Kings were too harsh and Eibachs too low.
I love my Tein SS's.
Peter.
STV
Postby STV » Sat Oct 07, 2006 7:50 am
so if i did just upgrade the shocks to konis, would the ride be the same height?
is it more controlled with the shocks only changed, and is there a NEED to do the springs as well?
sorry for all the questions... i always thought i would leave the suspension stock, and i am not so sure now :? I
havent done much reading on suspension mods either, so i am not really certain what type of upgrade would suit me..
