Mating universal O2 sensor to factory wiring.
mightyrollaman
Postby mightyrollaman » Wed Sep 27, 2006 7:24 pm
I bought the ACA single wire universal 02 sensor from Repco today for my NA6 and am wondering what the best way to mate it to my factory loom is.
The replacement 02 sensor's wire ends with just a cut and isn't as long as the factory wire. I was thinking of just mating new and old wires together with bullet connectors. Will this do the job or is it imprtant enough to require a solderd connection?
By the way, I bought it for under $40, pays to know people.....
The Rolla is mightier than the sword.
mightyrollaman
Postby mightyrollaman » Thu Sep 28, 2006 2:12 pm
Aw, c'mon guys?
Garry
Postby Garry » Thu Sep 28, 2006 3:09 pm
Your bullet connectors will be fine.
And that will make it easier for next time too. Just make sure you do a good job of installing the connectors and the total wire length should be similar to the factory wire length. I dont think it's possible to solder that wire. Isn't it stainless steel or something non-copper based anyway?
Babalouie
godfather of saké
Postby Babalouie » Thu Sep 28, 2006 7:08 pm
My universal one on the MX5 is using bullet connectors. IIRC the wires were a silver colour and solder didn't stick to it. So crimp-on bullet connectors were the only way to do it.
On the Luce I used a spade connector, which was then sealed with thick heat shrink so that it would never ground against the body.
mightyrollaman
Postby mightyrollaman » Thu Sep 28, 2006 10:07 pm
Awesome gents, I'll hop right on it.
Matty
Postby Matty » Fri Sep 29, 2006 11:50 am
yup, the stainles wires are basically impossible to solder, and solder's less reliable than crimping anyway. Just use a GOOD crimping tool.
jules
Guitar Hero
Postby jules » Fri Sep 29, 2006 1:31 pm
Got a part number or any details of that sensor.
Jules
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Fri Sep 29, 2006 1:38 pm
jules wrote:Got a part number or any details of that sensor.
Jules
I have a spare (used, but functioning) at home - and repco has them for around $80.
jules
Guitar Hero
Postby jules » Fri Sep 29, 2006 1:42 pm
I imagine mine's OK. Just not sure how much longer past 125k it should hang in.
Jules
mightyrollaman
Postby mightyrollaman » Fri Sep 29, 2006 11:43 pm
Jules
ACA ROX201
Has DENSO printed on the body and looks positively identical to the original. I wouldn't be surprised if it were the same part, just with a shorter wire, and no connector on the end.
jules
Guitar Hero
Postby jules » Mon Oct 02, 2006 10:24 am
Much thanks and happines to your family :D
Jules
mightyrollaman
Postby mightyrollaman » Mon Oct 02, 2006 6:53 pm
The original has:
ND 065500-1920 B61R 10K
embossed around the body, while the new one has:
DENSO JAPAN 5510 9F
Other than this, the two are identical.
jules
Guitar Hero
Postby jules » Tue Oct 03, 2006 11:47 am
So what's retail given you \"know someone\". :D :D
Jules
mightyrollaman
Postby mightyrollaman » Wed Oct 11, 2006 12:17 am
From memorey it was about $67.
Users browsing this forum: Google [Bot] and 5 guests
