It's bushes, common problem...
I think it's the lower a arm bushes that go from memory, someone will confirm though I'm sure.
Help! Clunking noise from the front!
- PT
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
- Boags
Hmmmmmmmmmm
I had the same noise the other day... Sounds like a project for dodgy day III
Price for the bushes?
Boags
Boags
- PT
From memory, about $600
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
they easyest way to check from wheel baring movement is this, Jack the car up and grab the wheel at 12 and 6 o'clock. and try to wabble it up and down , in and out sorta thing, if it has movement then it is probly a wheel baring, when u wabble it look for the movemeent. Put your hands at 3, and 9 then try to wabble it side to side( not turning the steering wheel) if their is movement then its probly a tierod end or a tie rod where it joins the rack, again if their is movement try to see what part is moving.
hope u can understand this.
dab wrote:Jack the car up and grab the wheel at 12 and 6 o'clock. and try to wabble it up and down , in and out sorta thing, if it has movement then it is probly a wheel baring, when u wabble it look for the movemeent. Put your hands at 3, and 9 then try to wabble it side to side
sounds like the latest dance craze,
just joking
