Mating universal O2 sensor to factory wiring.
I bought the ACA single wire universal 02 sensor from Repco today for my NA6 and am wondering what the best way to mate it to my factory loom is.
The replacement 02 sensor's wire ends with just a cut and isn't as long as the factory wire. I was thinking of just mating new and old wires together with bullet connectors. Will this do the job or is it imprtant enough to require a solderd connection?
By the way, I bought it for under $40, pays to know people.....
- Garry
Your bullet connectors will be fine.
And that will make it easier for next time too. Just make sure you do a good job of installing the connectors and the total wire length should be similar to the factory wire length. I dont think it's possible to solder that wire. Isn't it stainless steel or something non-copper based anyway?
- godfather of saké
My universal one on the MX5 is using bullet connectors. IIRC the wires were a silver colour and solder didn't stick to it. So crimp-on bullet connectors were the only way to do it.
On the Luce I used a spade connector, which was then sealed with thick heat shrink so that it would never ground against the body.
- Matty
- jules
- Guitar Hero
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
jules wrote:Got a part number or any details of that sensor.
Jules
I have a spare (used, but functioning) at home - and repco has them for around $80.
- jules
- Guitar Hero
Jules
ACA ROX201
Has DENSO printed on the body and looks positively identical to the original. I wouldn't be surprised if it were the same part, just with a shorter wire, and no connector on the end.
- jules
- Guitar Hero
- jules
- Guitar Hero
