Fuzzlets Final Fang
Moderators: timk, Stu, -alex, miata, zombie, Andrew, AJ
- Fuzzlet
Fuzzlets Final Fang
Due to next my engine being rebuild and turbo'd (starting) next tuesday, I was thinking of going for one last run up the old pac on thursday night 28/9. Thinking an 8pm meet at the truckstop at berowra or so.....Not gonna be too wild a night, as Id rather be getting the car turbo'd, rather than also going to a panel beater
- nath
- nath
- Fuzzlet
nath wrote:hmmm. could it start with 'M' and end in 'ania'?
PS: Fuzzlet, I'll try and make it - although this will be dependent on whether I can fix a new-found coolant leak in time - PM me your mobile number and I will keep you posted as to whether I show or not.
Haha you guessed right
- StanTheMan
- nath
Zoom-Zoom wrote:Good thing is, we show up 99% of the Skyline drivers, 200kw+ is only good in a straight line (they still handle like a boat)...
Mate, not interested in showing anyone up, just very much aware that as soon as you add a group of skylines into the mix it draws too much of the wrong attention. No one assumes anything when 3 or 4 MXs are seen together....
Call it once bitten twice shy.
Have a good time though guys...
- Bevan
That's OK then. Cause the others are meeting at 8PM at the truckstop so they should miss the skylines by a good 15 minutes.Zoom-Zoom wrote:Anywho!! 7:30pm meet at Mt colah Maccas... If you're interested...
- Fuzzlet
nath wrote:enthusiasm for old pac on thursday night suddenly lessens...
Na it was good. Slowest run ive had between mt white and calga - got stuck behind 6 skylines, then top of kariong hill and into gosford, was doing the speed limit and over took them lol.
StanTheMan wrote:why do you go so farking early !!!!!
Because of work the next day...Once I get my car back Ill go for a run late night
- StanTheMan
Fuzzlet wrote:nath wrote:enthusiasm for old pac on thursday night suddenly lessens...
Na it was good. Slowest run ive had between mt white and calga - got stuck behind 6 skylines, then top of kariong hill and into gosford, was doing the speed limit and over took them lol.StanTheMan wrote:why do you go so farking early !!!!!
fair enough ...should be good.
