TEIN Coilovers
TEIN Coilovers
For you guys with adjustable height coilovers, do you have the same height all round? front lower than rear? (or vice versa). Which would be the best setting for street/track?
Also, what damping setting do most people have on the street with TEIN FLEX?
Thanks
Thanks
- Brad
My SS are set to about 1cm lower than factory with a few extra mm on the drivers side to allow for weight on that side. Not properly corner weighted by any means but the 50/50 distribution of the MX5 makes an equal setting about right.
FWIW i have my dampers set to 10/10, 16 be hardest for the road and 14/12 for the track.
- fish
I have mine on around 10/10 for the street and 16/15 for the track . I am finding they aren't siff enuff for my liking on track I may get a beefier spring i think
born again 1994 NA8 2F RACE CAR ....No 42
- Brad
Yeah, it's the springs that will really make a difference to the feel of the car on the track but you don't want to overspring the dampers. I found the harder I went on the shocks, the more grip I had on smooth surfaces but as soon as I came through a bumpy section it was loosing grip. Makes sense.
- pcmx5
- Vehicle: ND - 2
- Brad
Richee wrote:Out of the box settings for my SS also.
Set to 10/10, must play with the settings some day
That's the best part. Try setting it to 15 clicks from hard (softest setting) and drive it for a day, then go to full hard and the difference is incredible and way more than I was expecting.
- Brad
The Pupat wrote:Raised a tiny bit at the front is the best setting for a car around a race track. Though I haven't tried it to find out.
What's the basis for setting up this way then and what car are we talking about here?
Brad wrote:The Pupat wrote:Raised a tiny bit at the front is the best setting for a car around a race track. Though I haven't tried it to find out.
Better grip all round IE acceleration and more stable under brakes. Works for just about all Front Engined RWD.
http://www.performanceforums.com/forums/showthread.php?t=67204662 Read posts by edo, he's usually fairly good and setting up cars to be quick.
'92, Red, Hardtop, Noisy CAI, Even more Noisy Exhaust, AVO Shocks with TJR Springs (Not so Fuli drifto speco).
- Brad
Lev wrote:I've got mine set to same height as it was when it came out the box. I drive them 3 clicks off the hardest. Surprised that others have theirs so soft?
It all depends on the streets you drive on. Where I live there is a lot of redevelopment going on so they are constantly digging the road up and re filling it. Stiffer does not mean more grip if the spring can't rebound quick enough to follow the road.
- rhysk
Brad wrote:Where I live there is a lot of redevelopment going on so they are constantly digging the road up and re filling it.
Tell me about it
I have enough trouble with Konis and progressive rate Kings.
Users browsing this forum: No registered users and 34 guests
