Digital Air pump at Servo!!!
Ok, maybe i have been living under a rock for the last 5 years, but I went to a different servo today and they had a digital air pump where you select the pressure and it fills the tyre for you!!!
so you can get it exact every time!!!
just thought i should share cos many people would be very particular about their pressures
NB8A
- AJ
LOL........yep, BP have had 'em for years mate, altho, there HAS been some heated discussion over their accuracy & you've probly opened another COW........just for the record, i used one friday afternoon & then checked it with my manual pressure gauge & it was spot on
XMX5 Rogues
- Boags
I used one and then went to a defensive driver training day - all 4 were different...
I used a different one and all four were the same...
It depends on how often they are calibrated. Most are not calibrated often.
Boags
PS - I haven't seen one of the old ones at a servo in ages...
Boags
- SuperMazdaKart
- irwin83r
Re: Digital Air pump at Servo!!!
Insurgence wrote:Ok, maybe i have been living under a rock for the last 5 years, but I went to a different servo today and they had a digital air pump where you select the pressure and it fills the tyre for you!!!
where do you live??
- Boags
bruce wrote:The next big thing is they will charge you to pump up your tyres! (Air ain't free y'know). It will happen soon-ish and very quietly.
They already do in the UK. Not all servos have air facilities, and those that do generally charge 20-50p (50c-$1.20) to use it.
Boags
- Caffeine
Users browsing this forum: No registered users and 173 guests
