problem with RAIN and my NC
- Mr_Q
- Mazda Mandi
- Rocky
- Concerned Citizen.
Like MrQ I'm wondering where you are parking as it usually takes a while for enough leaf-type fragments to build up & block the drain holes. Parking near trees with tiny leaves is best avoided as they end up in everything - air vents, doors, under bonnet. As suggested, coathanger/insulated wire is a suitable instrument for clearing drain holes.
- Boyracer
- MX-5 Encyclopedia
You have to work out if it is the floor at the passenger side footwell or back behind the seat...if the drain holes for the soft top are blocked the water comes down behind the seat...if it is at the footwell it's probably the A/C drain pipe...assuming everything is the same on a NC as on a NA/NB...
- Bevan
Users browsing this forum: Google [Bot] and 6 guests
