Rear Camber bolt question
nfs13b
Vehicle: 10AE - Turbo
Postby nfs13b » Mon Sep 11, 2006 11:33 am
Hey, I have another question/problem in regards to my mx5.
My rear wheels keep moving torwards (Toe In??). It seems that the camber bolts (If thats the right word) arent holding in place and are moving under load and are moving towards the front of the guard.
I keep moving them back but it just doesnt help.
Is anyone else hoving this problem, do I need to get new bolts and will that fix the problem or can I get the alignment to how I need it and then tack weld the bolts into place?
MX5 13B - NFS Racing
PRO-MX5 PB 7.46 @ 179mph & 1.07 60ft
Matty
Postby Matty » Mon Sep 11, 2006 11:47 am
How old is your car? At some point (mid-90's?) they revised the camber bolts to have a better plate design and a finer pitch thread, which means they can be tightened more.
Order them at a Mazda dealer: Part number NAY9-26-6AZ is the whole bolt, plate and nut kit.
nfs13b
Postby nfs13b » Mon Sep 11, 2006 11:59 am
Its a June 1989 model.....
Any idea on the cost of the replacements and am I going to need 2 per side or do they come in a set?
Matty
Postby Matty » Mon Sep 11, 2006 2:35 pm
each kit is one bolt, one plate, one nut. You'd need 8 in total for both ends of the car.
My records show I paid $99 for a set of 8... so about $12 each
nfs13b
Postby nfs13b » Mon Sep 11, 2006 2:39 pm
Cool Thanks for that, I might get one side and see if it fixes the problem. Its a real pain in the ass moving the wheels back after each race.
nfs13b
Postby nfs13b » Mon Sep 11, 2006 3:09 pm
Just called Mazda, superceded part number is NA01-28-473
$18 each, 2 per side??
adamjp
Postby adamjp » Tue Sep 12, 2006 8:12 pm
2 per corner.
1 at each attachment point for the lower wishbone.
Adam
Users browsing this forum: Google [Bot] and 6 guests
