Digital Air pump at Servo!!!
Insurgence
Postby Insurgence » Sun Sep 10, 2006 4:29 pm
Ok, maybe i have been living under a rock for the last 5 years, but I went to a different servo today and they had a digital air pump where you select the pressure and it fills the tyre for you!!!
so you can get it exact every time!!!
just thought i should share cos many people would be very particular about their pressures :)
NB8A
AJ
Postby AJ » Sun Sep 10, 2006 4:32 pm
LOL........yep, BP have had 'em for years mate, altho, there HAS been some heated discussion over their accuracy & you've probly opened another COW........just for the record, i used one friday afternoon & then checked it with my manual pressure gauge & it was spot on 8)
XMX5 Rogues
Boags
Postby Boags » Sun Sep 10, 2006 4:44 pm
I used one and then went to a defensive driver training day - all 4 were different...
I used a different one and all four were the same...
It depends on how often they are calibrated. Most are not calibrated often.
Boags
PS - I haven't seen one of the old ones at a servo in ages... :oops:
Adam_NAclubman
Postby Adam_NAclubman » Sun Sep 10, 2006 7:20 pm
The ones at the BP's I use all seem to match my guage, so I'm happy
SuperMazdaKart
Postby SuperMazdaKart » Sun Sep 10, 2006 7:41 pm
the BP ones also take hot air out, but probably still best to re-pressure on cold tyres for better accuracy
rodent
강남 스타일
Postby rodent » Sun Sep 10, 2006 7:43 pm
The trick with these things is to always make sure you've got a good seal, since the friggin clips are usually broken from people running over it! :evil:
Postby bruce » Wed Sep 13, 2006 3:22 pm
You have been living under a rock - they've had those for at least 5 years.
irwin83r
Re: Digital Air pump at Servo!!!
Postby irwin83r » Wed Sep 13, 2006 10:43 pm
Insurgence wrote:Ok, maybe i have been living under a rock for the last 5 years, but I went to a different servo today and they had a digital air pump where you select the pressure and it fills the tyre for you!!!
where do you live??
Insurgence
Postby Insurgence » Thu Sep 14, 2006 12:00 pm
haha i'm around heidelberg.
must be the servo which i usually go to which doesnt have a digital pump!
also i have only had my car this year, so previous to that there was no need for me to investigate pumping up tyres :mrgreen:
NB8A
Postby bruce » Thu Sep 14, 2006 2:54 pm
The next big thing is they will charge you to pump up your tyres! (Air ain't free y'know). It will happen soon-ish and very quietly.
Insurgence
Postby Insurgence » Fri Sep 15, 2006 2:37 am
i sincerely hope you are joking :(
NB8A
Postby Okibi » Fri Sep 15, 2006 3:15 am
:lol: been around for years!
One of our Forum members (a kiwi) works on these systems and says they're very accurate.
Boags
Postby Boags » Fri Sep 15, 2006 1:04 pm
bruce wrote:The next big thing is they will charge you to pump up your tyres! (Air ain't free y'know). It will happen soon-ish and very quietly.
They already do in the UK. Not all servos have air facilities, and those that do generally charge 20-50p (50c-$1.20) to use it. :shock:
Boags
Caffeine
Postby Caffeine » Sat Sep 23, 2006 10:27 am
The one at the local BP has a real problem with my rear left tyre. Always tries to inflate it to 50psi, then goes \"ERR\" and deflates it to 15 or so
rain902
Postby rain902 » Mon Sep 25, 2006 9:25 am
Insurgence wrote:haha i'm around heidelberg.
the 7-11 on heidelberg rd alphington has had it for 10 years. :shock: :shock:
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
