Intercooler - size / placement / fitting ????
Just wanting some info on Intercooler sizing for a NA6.
Also, the fitting and placement etc. maybe even plumbing ??
Where do the factory place theirs ? And their specs ?
Thanks for your help.
Regards.
Regards.
- Garry
The factory never produced an NA 1.6 turbo. In the UK the UK Mazda distributer did something similar to the Australian SP with an NA6 except that it was all done outside of Mazda and sold as a kit that could be fiited to new cars and retrofitted to used cars. I'm not sure if it even had an intercooler. Were intercoolers as popular in the early 90's as they are now?
- Russellb
- RIP Nov 2014
Intercooler are best placed infront of the Radiator
As for there Size on the NA with out A/C you can fit a 650mm x350mm core in there with out to much hassle.
This is the core I put in my Old mans car
It was an Ebay jobbie and on the Dyno with 5PSI the intake temps were down around the low 20's
I have Kept the A/C but had to remake every bit of pipr work
My ClubmanRebuild
MX5 SE Rally car is HERE
Garry wrote:Where do the factory place theirs ?
There is a Vic club member (JohnD)with that kit in his Neo NA. I'm pretty sure there is no intercooler. The Melbourne based turbo shop that fitted Johns still has one of these kits for sale. $3500 for the kit + $1500 to fit it. It uses the standard ECU, with a piggy back. Nice looking kit, very well made as you would expect given it was sold in the UK with full warranty.
J
- lowmiata
- Sean
- Russellb
- RIP Nov 2014
Sean wrote:
damn that's a clean engine!
It would want to be it hadn't even been Filled with oil at that stage
My ClubmanRebuild
- Matty
Juffa wrote:There is a Vic club member (JohnD)with that kit in his Neo NA. I'm pretty sure there is no intercooler. The Melbourne based turbo shop that fitted Johns still has one of these kits for sale. $3500 for the kit + $1500 to fit it. It uses the standard ECU, with a piggy back. Nice looking kit, very well made as you would expect given it was sold in the UK with full warranty.
J
I believe the BBR kit came with an intercooler, but it was a tiny jobbie (smaller than the SE's) and mounted behind the radiator...
- sabretooth
My intercooler is 500x200x70 and sits pretty much where everyone else's does. This size slid up between the front chassis rails perfectly with a couple of millimetres each side. $240 off ebay...
What turbo are you running russellb? Because that intercooler is massive! I would expect to see it bolted up to a T78 or a T51R or suchlike. Any idea what the pressure drops for it are? By the way, like Sean said, that is the cleanest engine I've ever seen! Wish mine looked like that...
- sabretooth
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
- sabretooth
