NA8 HEADLIGHTS GO UP BUT WON'T GO DOWN....FIXED
fish
Postby fish » Tue Sep 05, 2006 12:26 am
As the title says what would be the reason for this any suggestions ??
they go up with the headlight switch but don't go up or down with centre console switch...
Any advise greatly appreciated
born again 1994 NA8 2F RACE CAR ....No 42
JBT
Postby JBT » Tue Sep 05, 2006 7:58 am
I suspect the plug has disconnected from the centre console switch.
StanTheMan
Postby StanTheMan » Tue Sep 05, 2006 8:52 am
If my memory serves me correctly.....On My NA the lights don't work if the plug is left unattached.....but certainly worth checking.
fish
Postby fish » Tue Sep 05, 2006 10:09 am
nah plug is attached allright
JBT
Postby JBT » Tue Sep 05, 2006 10:14 am
If the doors go up but not down via the stalk switch and the centre console switch does nothing, then the centre console switch has died or the plug is disconnected. All \"down\" power to the doors is routed through that switch.
Other possibility is retractable headlight unit internal failure.
zhenjie
Postby zhenjie » Tue Sep 05, 2006 12:30 pm
Had this problem when my ground wire was not attached correctly.
JBT
Postby JBT » Tue Sep 05, 2006 12:35 pm
I think all the grounds for the headlight system go through the multiple connection in the engine bay on the passenger side under the washer bottle. Worth cleaning/checking.
Fuzzlet
Postby Fuzzlet » Tue Sep 05, 2006 4:40 pm
I had this problem, but Fuzzlets dodgy wiring to the rescue solved it. The gremlin that stopped making it work is now making it work, and i dare not try to understand how
JBT
Postby JBT » Tue Sep 05, 2006 5:44 pm
WTF :?:
Fuzzlet
Postby Fuzzlet » Tue Sep 05, 2006 7:42 pm
Haha sorry ill reword that. The lights randomly stopped going down, so i rigged up a system with a couple of relays to bypass the factory wiring
JBT
Postby JBT » Wed Sep 06, 2006 10:38 am
So what was fixed :?:
rodent
강남 스타일
Postby rodent » Wed Sep 06, 2006 10:46 am
LOL so no more dodgy lazy-eye mod for you then eh Fuzzlet?
fish
Postby fish » Wed Sep 06, 2006 10:51 am
well basically when I stripped all the under dash back heater motor, ducting
etc etc I didn't plug back in a plug a particular plug ...it is in the heater bundle
so i didn't think it would be required to make the lights work ..very weird
apparently there is a lot of inter related wiring going on in the MX5 ...thus
most guys setting up race cars don't hack into the wiring bundles at all they
just cable tie it all up as is...
JBT
Postby JBT » Wed Sep 06, 2006 11:08 am
fish wrote:well basically when I stripped all the under dash back heater motor, ducting etc etc ...
Aaahah. A vital clue as to the cause.
Garry
Postby Garry » Wed Sep 06, 2006 11:11 am
I love how people leave out small clues as to what might be causing the problem.
Something along the lines of \"I ripped out half my dash wiring and now my headlights dont go down\" would have been a lot more helpful than the original post. :roll:
