just tonight my car wouldnt hold idle.. would be fine driving along and if i kept revs up but as soon as i let it sit, say at some lights, the head lights would dim and the car would pretty much stall..
so what you think i should check first?
irwin83r wrote:so what you think i should check first?
JBT wrote:irwin83r wrote:so what you think i should check first?
Put a voltmeter on the battery and see if it indicates 12 volts. If 11 or less it's dead and won't start the car. Start car and see if volts increase to 13-14. If no change the alternator (maybe a diode) is dead.
No voltmeter? Go to auto electrician ASAP.
