Siezed bolts :cry:
JBT
Postby JBT » Thu Aug 24, 2006 8:52 pm
Might be worth buying a cam cover gasket and give it to whoever does your cam belt change if you don't need to use it on the weekend.
I must ask though, why were you taking the coil pack off anyway?
Insurgence
Postby Insurgence » Thu Aug 24, 2006 10:01 pm
http://aus-cartalk.com/viewtopic.php?t=17286&highlight=
http://aus-cartalk.com/viewtopic.php?t=20053&postdays=0&postorder=asc&start=15
Basically the coil packs are playing up and i am replacing them :)
Brett was so kind as to mail me his old coil packs. alas i was trying to install them :mrgreen:
NB8A
adfox
Postby adfox » Sun Aug 27, 2006 10:16 am
If you get really desperate, i've found using a mig welder to weld a good nut to the top of the broken bolt works really well. You need to get the whole thing really really hot, almost dripping, then let it cool. It will then just wind out with no problems. You can use this method to get broken exhaust studs out too, even if they are a bit below the surface. I weld a washer on to them first, then weld a nut to the washer.
Insurgence
Postby Insurgence » Sun Aug 27, 2006 5:46 pm
Spot the difference.
gave up on getting the bolts out :roll:
NB8A
Insurgence
Postby Insurgence » Sun Aug 27, 2006 6:15 pm
I'm happy to report that it doesnt seem to be showing any signed of rough idling. :mrgreen:
will experiment last on in the week but for now :mrgreen:
NB8A
AJ
Postby AJ » Sun Aug 27, 2006 6:18 pm
ok, i can understand why you need the wine......frustration........& the book........waiting for gasket goo or something to dry..............but what the hell was the gladwrap for???? :lol: :lol: :lol:
XMX5 Rogues
Insurgence
Postby Insurgence » Sun Aug 27, 2006 6:29 pm
to reduce the amount of metal filings going into the cover when i hacksawed the ignition coil bracket :shock:
NB8A
AJ
Postby AJ » Sun Aug 27, 2006 6:36 pm
:shock: :shock: sorry i asked now............LOL :lol:
XMX5 Rogues
JBT
Postby JBT » Sun Aug 27, 2006 6:37 pm
Why not take the cam cover to someone who can drill the bolts out?
Insurgence
Postby Insurgence » Sun Aug 27, 2006 6:43 pm
i guess i could have drilled them out myself.
1) too lazy
2) what difference would it make?
i guess this method is a little dodgy, i just want it to work.
famous last words.
i still have a unhaxord bracket if i ever feel the need to drill out the bolts
I also want to thank brett again for sending me his coils :D
NB8A
