SP Spark Plugs
Garry
SP Spark Plugs
Postby Garry » Wed Aug 09, 2006 10:08 pm
Does anyone know what the Mazda Motorsport recomended spark plug heat range for the SP is? What is everyone else using?
Garry
Postby Garry » Thu Aug 10, 2006 3:52 pm
Anyone??????
bigdog
King of the kennel
Postby bigdog » Thu Aug 10, 2006 4:14 pm
Pretty sure I'm running NGK BRK7ES-11 plugs - you should give Daniel a ring to check though. Didn't go for iridium jobbies as I change em regularly anyway, so 'long life plugs' don't interest me :D
Garry
Postby Garry » Thu Aug 10, 2006 4:44 pm
Thanks BD, I'm running 6's atm and I think they may be a bit hot. I'm trying to find out what the specs are but it seems like it's one of the closest secrets at Mazda for some reason.
Daz
Postby Daz » Fri Aug 11, 2006 9:03 pm
I have changed mine but i cant remember the number its either 7, as suggested or 6. I found out at the time they went in. I think it was CT that told me.
Silver SP - PSS9, 1:10:58
Garry
Postby Garry » Sat Aug 12, 2006 1:31 am
I put some 7's in tonight and I'll see how they go. It had 5's in it at one stage. :shock: Around the same time it was playing up last January. I'm not sure if they were installed at the last service before I went on holidays or if the Mazda place in Albury gave me the wrong ones. It's a worry when Mazda dont even know the correct parts for your car.
Daz
Postby Daz » Sat Aug 12, 2006 9:34 am
I argued with Newells over the plugs, they said it took the same ones as any other mx5 as the engine was the same. It was only resolved when they took one of them out and looked at the numbers ! Dont trust the dealer...
Sean
Postby Sean » Sat Aug 12, 2006 8:10 pm
Most shops will sell you normal MX5 ones as that's all thier book tells them.
I've been running 8s in mine for a while in the NGK V power range - goes like a dream - only thing we had to do was gap it down to .9mm when we ran high (15+psi) boost.
CT
Postby CT » Fri Aug 18, 2006 8:47 pm
7s would be the minimum to use I reckon. If you've upped the boost, definitely try 8s and check the plug electrode colouring after a thousand clicks or so. 5s :shock: :shock: :shock: Mazda can be so funny....the race car uses 6s and it's NA! 8)
Garry
Postby Garry » Sat Aug 19, 2006 12:59 am
Thanks CT. I've got 7's in it now and so far so good. I'll pull the plugs after a few km and see how they look.
