passenger side foot well had a puddle in it!? couldnt find any leak paths though, as in wet trails of carpet or what not to suggest where it was running in from.
anyone know if theres a common prob here? or is it just something to live with
Alf wrote:Shouldn't need to be something to live with:
1) If the water's green, your heaters leaking. Expensive PITA.
2) If you've been running the aircon, check that the hose that takes the condensate away isn't blocked. This is a common problem.
3) Check the drain holes at each side of th soft top rain rail. These commonly get blocked and can be cleaned with a coathanger.
Alf
irwin83r wrote:Alf wrote:Shouldn't need to be something to live with:
Alf
woo No. could be it! where i check that?
have had the AC on all day sat, i must be really hot or something the windscreen wouldnt stop foggin up![]()
wheres the drain located?
