i dont want to break anything, and i have slim access to the boot from where i just removed the centre stoplight - attempts to find key with coathanger and magnet have so far been unsuccessful...
StanTheMan wrote:some choice's
1: Drill out lock.....may or may not work. But it means either having a different lock on your boot once you repair it. Or spend about $400 at mazda changing all the locks so you can keep all the locks with 1 key.
2: break the rear driverside light reach in. & unlock. also costly.
3: check your balls......make sure they are still in the bag. as both options above require big testies.
4: hope someone comes up with a cheaper alternative.
5: get someone to kick you in the groin.....until they are black & blue....to remind you to get a spare key cut for next time.
Gramps wrote:Take the car to a locksmith. He will have the tool which he can use to manipulate your locking mechanism without doing any damage. It is going to cost you whichever way you go but these guys can do it in a trice.
rain902 wrote:StanTheMan wrote:some choice's
1: i did have a halfassd go @ manipulating the lock, but the magnet was more tempting. Unfortunately, I have retrieved half of the socket set from in the boot, but alas, no key.
2: yes, but would force me to replace it with much wanted, but cost-unjustified "bling" items - a tempting alternative...![]()
3: scratching them has proved to not offer any better solutions...
4: already done, without success.
5: when i retrieve the key, i am going to do that job myself...
Juffa wrote:Have a look at this thread on the big forum ==>> http://forum.miata.net/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=5;t=025616
It seems that one way to get into the boot is to drill a small hole in the panel under number plate. This gives you access to the lock mechinisim.
See how you go.
ps....once you get the keys, get a spare cut![]()
J
rain902 wrote: dopey as I am knows how to do it...
mexi wrote:I don't know if you'd be able to squeeze yourself inside a mx5 boot though...
rodent wrote:rain902 wrote:these tools? thats my next option...
Oooh where do I get me one of these??
jonno.
