glen73 wrote:waking up for work has never been so much fun......
I know the Feeling I took the long way to work this morning (50km)
usally only 10km
it has been a long process but I have never had the car off the road for more than 4Hr's
I am very happy with the results. need to do a bit of finishing off the Air cleaner pipe is held on very
dodgy and is sucking in a heap of hot air from the Exhaust
Also the oil feed line is waving around in the breeze and the Air
Temp sensor is on the inlet to the turbo and it needs to be as close to the
T/Body as possiable. and then the cold air duct in the Headlight cover
For the time being will keep the Boost down to 7PSI this will keep the intake temps under control.
Talk to my dyno Guy and its booked in next friday for a tune (done by me just using his dyno) Hope there is 130 + Kw waiting to be recorded
