Holy Hell!!! Timing advance...
Boags
Postby Boags » Fri Jul 21, 2006 11:49 pm
I think so JB :?
The clip for the timing light was on no. 1. I'm going to have another look at it in the morning. That little spec that we thought was the mark couldn't be it. We had to be overlooking something, so i will check and recheck!!
Boags
JBT
Postby JBT » Sat Jul 22, 2006 9:29 pm
That's what you're looking for Boags.
dab
Postby dab » Sat Jul 22, 2006 11:44 pm
When you recheck it check it with and without the terminals bridged. The timing should change if it doesnt it means you are putting it in the wrong terminals or you are not getting a good connection.
What kind of paper clip are you using? is it one of those paint coated ones as that wont be able to transfer the current.I find it best to use a split pin that u can bend to the correct shape.
If your engine is running that much timing you may not hear it ping without the use of a Stethescope??? those things doctors listen to you heart with. But your combustion will be very very hot and not only may your pistons be pitted your ringlands could be severly opend up/cracked, and your head could be damaged also. I think you may have the wrong mark or incorrect terminals. If you really want to check your mark you will have to line up your cam markings and see if the mark is on TDC. Hope you get it sorted.
JBT
Postby JBT » Sun Jul 23, 2006 6:43 am
You can check TDC by removing #1 plug and checking when #1 piston is at full height with a screw driver resting on top of the pistion. If you get TDC but no timing mark, turn the motor another 180 degrees.
Boags
Postby Boags » Mon Jul 24, 2006 8:48 pm
So high revs is not good with this much advance?
Any Brisbanites feel confident enough to give a second opinion on my timing? I'd be greatly appreciative!!
Boags
JBT
Postby JBT » Mon Jul 24, 2006 10:12 pm
Have you had a good look at the photos and confirmed that you have the correct timing mark? Have you done the TDC check with a screwdriver (or piece of dowel) yet?
I'm happy to have a look at it if you want to pop by.
