Holy Hell!!! Timing advance...
Boags
Postby Boags » Thu Jul 20, 2006 11:21 pm
Hi all,
I tried to advance my timing today in the NA6, and i REALLY hope i got something wrong, becasue it looked like my timing was already advanced, to what i estimate is about 20deg... :shock: :shock: :shock:
I unplugged my fan, set up the timing light, and bridged the little black box with a paper clip, and pointed the light at the pulley. I must admit, i expected the TDC mark to be a bit larger than it was, and i hope what i was looking at was a mark of some description and not the TDC marker (it was a dot on the back edge of the pulley, not a line, and quite faint).
I have been running 91ron in my car since i bought it in Jan, and haven't noticed any pinking, so i'm a bit lost for ideas????
Hopefully someone at QR can give me a hand tomorrow, but please let me know if you can see i have forgotten a step somewhere.
Boags
StanTheMan
Postby StanTheMan » Thu Jul 20, 2006 11:39 pm
Holy hell.....20deg. :shock:
Id be prolly reduce this a little
I've heard of 18 deg.....not 20
Mine runs on 16
Boags
Postby Boags » Thu Jul 20, 2006 11:57 pm
Is what i described the correct process though, and is the timing marker just a little dot? Not a great big f*&k off line????
AHHHH, i'm gunna blow my engine up :cry:
Boags
StanTheMan
Postby StanTheMan » Fri Jul 21, 2006 12:11 am
its a small line. idleing at around 850rpm +/=50 if i recall correctly.
all light & radio shut off.
if you are unsure, there are isntructions on mita.net on how to do it.
PT
Postby PT » Fri Jul 21, 2006 8:27 am
Now you know why that NA was so much quicker than the rest when you were test driving.
I was running 16deg BTDC with my old NA, the SE is still completely stock.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
JBT
Postby JBT » Fri Jul 21, 2006 8:39 am
Sounds right but instructions and piccies here.
Richee
Re: Holy Hell!!! Timing advance...
Postby Richee » Fri Jul 21, 2006 8:41 am
Boags'MX5 wrote:I have been running 91ron in my car since i bought it in Jan, and haven't noticed any pinking, so i'm a bit lost for ideas????
I am no expert but I dont think you could run at 20 deg on 91RON and not notice some/heaps of pinging.
Richee
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
PT
Postby PT » Fri Jul 21, 2006 9:11 am
I have dríven the car... definately didn't notice any pinging but yes, for a 1600 NA it went very very well!
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
jules
Guitar Hero
Postby jules » Fri Jul 21, 2006 1:45 pm
At 14 degrees on 91, Malibu can ping a bit. 20, I would be afraid..
Are you sure you have the ECU bridged correctly? I would be surprised if you are not getting pinging with that sort of advancement.
Jules
mio
Postby mio » Fri Jul 21, 2006 2:53 pm
What is this marker that you are looking at? It might be wrong, feel the edge of your pulley, there should be a little groove. This is the marker, place a dot of whiteout on this marker, then do your timing again.
Boags
Postby Boags » Fri Jul 21, 2006 6:22 pm
When i got in the car this morning the tank had about 5 litres left, so i fulled her up with BP Ultimate!!
:shock: Instantly more torque lower down, revs smoother and feels much nicer to drive. I had been blaming the lack of power on a new muffler i had installed after NATmeet, but that was about the time i stopped filling shazza with Premium, or at least 95ron.
I will recheck the timing none the less, making sure it is the right marker, and that all electrics are off, and set it to 16.
If this is infact set to 20deg+, what kind of damage would have been done by running 91 ron? I understand the concept of pinging, but how bad is it??? :frown: I hope i didn't wreck anything!
Boags
sabretooth
Postby sabretooth » Fri Jul 21, 2006 6:51 pm
What sort of timing light are you using? Are you sure it's not just registering waste spark and therefore doubling the timing? Waste spark means that spark occurs twice as often per cylinder - could this be throwing your light? I'm thinking maybe you are running 10 degrees.
Boags
Postby Boags » Fri Jul 21, 2006 9:29 pm
I hope so! To tell you the truth though, looked more than 20 :shock: I said 20 to be conservative and not freak anyone out, it looks more like 25-30 :shock: :shock: :shock:
I think it is a cheap timing light, so hopefully that is it.
And definate improvement with higher octane, so maybe it is at 12 or 14?
Boags
Sean
Postby Sean » Fri Jul 21, 2006 9:37 pm
How does teh timing light pick up signal?
Does it clip around a spark plug wire?
If so what wire are you clipping it over?
JBT
Postby JBT » Fri Jul 21, 2006 10:44 pm
Boags'MX5 wrote:I understand the concept of pinging, but how bad is it???
It's a bit like bashing the sh1t out out of your pistons with an ice pick. You'd know by now.
I think you need a second opinion Boags.
